LM3886 input resistence power
Old 1st June 2012, 01:47 PM   #1
francesco81rs is offline francesco81rs  Italy
Default LM3886 input resistence power
Hello everyone, my name is Francesco and is the first time that I write on this forum.
Sorry for my bad English!!!
I wanted to ask a little help...
For a lm3386, what is the right power for the input resistance and the resistance of feedback?
Can I use 1/8W, or is it better to stay on 1/4W?
Thanks to all.
Old 1st June 2012, 05:07 PM   #2
pacificblue is offline pacificblue  Germany
You can use 1/8 W, if you like.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 1st June 2012, 07:03 PM   #3
sgrossklass is offline sgrossklass  Germany
But avoid thick-film types if you're after lowest distortion. (Since you're asking about 1/8 W, I'm assuming we're talking surface mount parts.)
Referring to Figure 1 in the LM3886 datasheet:
1/8 W is perfectly fine for RB and Ri. You may want to go 1/4 W for Rf1, which sees the highest voltage swing and power dissipation of them all by far.
All of them should be preferably metal film (through-hole) or thin-film (SMD).
For lowest low-frequency distortion, capacitor Ci should be either a bipolar type or about 3 times as large as specified in the datasheet, though I don't think it should be all that important given that the IC has thermal feedback to contend with that increases low-frequency distortion anyway.
Old 4th June 2012, 08:03 PM   #4
Thank you very much for your reply.
I was doing the shopping list for components to build a 2-channel with the LM3886 in parallel - bridge configuration and i will use 2 board for each channel with 3 LM3886 in parallel and put in a bridge by a Lundahl input transformer.
The circuit diagram is as follows:
The only difference I see in the pcb I bought is the 8pF capacitor in parallel with the feedback resistor is printed as 47pF.
Any suggestion about electrical circuit or the type or brand of components is welcome!
Old 8th June 2012, 09:03 AM   #5
I found the solution to the question of the capacitor onto another discussion...
I think the capacitor is smaller for not limiting the bandwidth at high frequencies.
LM3886 input resistence powerHide this!Advertise here!
field coil resistence in modern units aldovan Full Range 0 12th December 2011 03:35 PM
LM3886 100k input jetbat Solid State 17 9th October 2009 03:54 PM
LM3886, power caps, input resistors, mute, and Cm. mudihan Chip Amps 3 21st December 2007 09:23 AM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Remove resistence to A75 for unbalanced use? Danyele82 Pass Labs 4 6th December 2004 10:57 PM
