| Chip Amps Amplifiers based on integrated circuits |
#11 |
Maxim has some nice low power IC's as well, like the MAX98310.
MAX98309, MAX98310 Mono 1.4W Class AB Audio Amplifiers - Overview
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#12 | |
Mini DC to DC Converter Boost Step Up Module Wide Voltage Input 2.5-25V to 5-25V | eBay Last edited by AmadeusMozart; 30th May 2012 at 11:44 PM. |
#13 |
http://www.nxp.com/documents/data_sheet/TDA7056B.pdf
this chip might do the trick without any booster, on 9 volts. |
#14 |
Yesterday i was looking through my parts bin looking for something to build a low power stereo amp for my MP3 player to run in my car , like an Ipod dock type thing ....
Anyways I found a HA13001 chip in my parts bin , it is appearantly a 2 x 5w into 4 ohms amp chip that runs off of 12v DC which is perfect for my car ..... So I did up a home made PCB from the datasheet curcuit and hooked it up to my MP3 player and a set of home theater speakers and a 12v dc PSU and it sounds pretty good , way better than the LM386 amps i have built ...... I don"t think they make them anymore but you can find them on the net , if you can find one I can supply you with a simple PCB design if you want to etch a pcb at home ...... |
#15 |
ICs designed for automobile use are generally single polarity supply from ~8Vdc to 16Vdc.
These are ideal for using battery power, except that excessive current draw may be a problem. TI have just released TPA2025D1 : 1.9W into 8r0 @ 1% THD from +3.6Vdc |
#16 |
Thank you to all of you for your answers, i think i have enough infos now ! This helps me a lot for my project. I hope I will be able to help you, if one day you need it.
#17 | |
So nice, that I rushed to download and *read* its datasheet ![]() Cool chipamp ... but not to be even mentioned here ... except as a curiosity. Light years away from any "DIY". Why? Well, for starters , its pinout is BGA (Ball Grid Array), forget hand soldering there. Even more, the package is match head sized; 1.5mm x 2 mm ![]() Oh well, too good to be true (for us I mean) ![]() So it looks like I'll have to go back to the chicken farm, light the kerosene lamp up, and grab a couple of my obsolete TBA820, which at least are through hole, DIP8, and can provide 3.6W RMS bridged out of a 9V supply. Oh well.
#18 |
schematics diagrams amplifier circuits 5w
#19 |
AN7522N will do the job nicely! I see them in Stereo CRT TV's all the time. (I salvage TV's for scrap and parts)
http://www.lemona.lt/LIUSE/Pdf/AN7522N.pdf It's a 2-channel BTL stereo amp designed for low voltage. I built an amp with one, and on only 9V it will fill the room with sound. It's easy to mount on a heatsink, and does not get very hot. Even though the pdf specs @ 8 ohms, I can drive 4 ohms easy with a bigger than stock heatsink, and it's still a relatively small heatsink. 6 ohms should be easy and loud!
You can call me Mad Professor, building crazy experiments in my Electronics Workshop |
| Voltage Differential Amplification | Stee | Solid State | 60 | 12th August 2008 08:54 PM |
| Relation between voltage gain and dB amplification | klitgt | Solid State | 9 | 18th August 2005 12:17 PM |
| Curent Vs Voltage amplification in Alephs | AR2 | Pass Labs | 26 | 21st December 2004 09:57 PM |
| power amplifier with one-stage voltage amplification | alex0 | Solid State | 5 | 7th February 2004 12:02 PM |
