Old 18th May 2012, 11:44 AM   #11
KSTR is offline KSTR  Germany
KSTR's Avatar
Ouroboros, could you check the open-loop gain/phase?
Run an AC analysis, plot Vout / (Vin+ - Vin-), that is, chip output divided by input pin differential.
Old 18th May 2012, 11:44 AM   #12
Ouroboros's Avatar
Just tried it now with the LM3886 model. Distortion with this at gain x21, Vin 1V 1kHz, load 4R give stupidly low figures for THD. Don't know why the 3875 simulates ok but not the 3886.
Old 18th May 2012, 11:51 AM   #13
Ouroboros's Avatar
Default TI LM3875 SPICE model
TI LM3875 Spice model (TINA)
Hopefully the O/L Bode plot should be attached.
Old 18th May 2012, 12:04 PM   #14
Ouroboros's Avatar
Default TI LM3886 SPICE Bode plot (TINA)
They seem to have cocked up the LM3886 model though...
Old 18th May 2012, 12:33 PM   #15
KSTR's Avatar
^^ Thanks.
I contacted TI, now that we know that TINA also shows the problem.
Faulty SPICE model of LM3886? - Audio Amplifiers Forum - Audio Amplifiers - TI E2E Community
Old 18th May 2012, 01:10 PM   #16
rumors is offline rumors  Italy
Originally Posted by rumors View Post
With model "PSpice" Work and AC analysis set:
http://www.diyaudio.com/forums/attac...1&d=1337346278
Bye
Old 18th May 2012, 01:29 PM   #17
Ouroboros's Avatar
Are you all sure that the MUTE behaviour is wrong? The data sheet says that if you leave the MUTE pin o/c or pulled to V+ the 3886 is enabled. To mute the amp you pull >1mA out of the MUTE pin (by connecting a resistor to 0V or V-)
Old 18th May 2012, 02:02 PM   #18
Ouroboros's Avatar
Oh-Oh, my fault. It appears that the MUTE function is muted when the pin is floating, and un-muted when >1mA is taken out of the pin. This seems strange, as if it were the other way round you could apply an automatic mute at power-up by connecting a large-value cap between the MUTE pin and 0V
Old 18th May 2012, 02:06 PM   #19
KSTR's Avatar
"Mute Function: The muting function of the LM3886 allows
the user to mute the music going into the amplifier by draw-
ing less than 0.5 mA out of pin 8 of the device. This is
accomplished as shown in the Typical Application Circuit
where the resistor RM is chosen with reference to your
negative supply voltage and is used in conjuction with a
switch. The switch (when opened) cuts off the current flow
from pin 8 to V−
, thus placing the LM3886 into mute mode."
Also the function is clear from the internal schematic. The main diff-amp is OFF when the MUTE pin is left open, while the auxiliary diff-amp is ON.
EDIT: Cross-post, I see.
In fact I like the MUTE and STANDBY features of the TDA7294 much better than the slightly akward MUTE of the LM3886.
Old 18th May 2012, 03:15 PM   #20
Bill_P is offline Bill_P  United States
Originally Posted by KSTR View Post
see my take on a correct bode plot estimation here.
Would you post the .asc file containing your LM3886 model?
Any spice models for the LM3886 ? gaetan8888 Chip Amps 5 29th June 2009 09:03 PM
Simulation Models for OPA827 and TINA-TI stef1777 Parts 8 13th March 2008 04:56 AM
Spice models LM3875 and TDA2050 Jarno Solid State 5 3rd February 2003 11:06 PM
Spice models JoeBob Solid State 18 25th April 2002 02:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
