Mauro Penasa MyRef vs simple LM3886 circuit
Old 21st May 2012, 08:48 AM   #41
soundnovice is offline soundnovice
Originally Posted by soongsc View Post
I would use the same amp for all bands unless the woofer is something like 12" or more.
does this mean that MyRef will not properly drive woofer of 12" or more size?
Old 21st May 2012, 08:51 AM   #42
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
It's more a question of sensitivity and desired SPL.
The My_Ref is a 46W amp.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 21st May 2012, 09:41 AM   #43
bcmbob is offline bcmbob  United States
Hey soundnovice,
When I was at stock builds of V1.2 and V 1.3 I started a project with some BPA-150s for the bottom of a bi-amped system. I still think it's a productive approach if one is using 4 ohm woofers, but I found the actual SPL to be about the same as the MyRef. One of the veteran MR builders, Tom E, has been perfecting a bi-amp - active crossover system for several months. You might get some good info with a PM and a search of his posts.
It should be noted that the addition of the Mundorf AG caps at C3 and C8, plus a larger transformer has given me all the deep, controlled and musical bottom end I can handle. With that combination the MyRefs do everything from shaking the house with pipe organ pedal notes to finely played bass lines in a jazz trio. The beauty of the MyRef approach, it's best feature is just letting what's being fed come through over the entire spectrum.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 21st May 2012, 09:53 AM   #44
soongsc is offline soongsc  Taiwan
soongsc's Avatar
It depends on how much voltage it will take to drive the woofer to max travel. You don't want the amp to max out before the driver. If you have an abundance of low frequency in music content, the summation can get pretty high.
Hear the real thing!
Old 21st May 2012, 12:04 PM   #45
R.I.P.
The required drive voltage to the speaker is determined by the SPL and the speaker sensitivity.
Bigger speakers tend to have higher sensitivity (more SPL for the same drive voltage).
A driver that is big relative to the other drivers in the speaker is likely to require less drive voltage than the other drivers, not more !!!!!!
By way of example:
a normal 8ohm 2way speaker with 6.5" & 1" drive units that are both 88dB/W @ 1m when assembled into a passive cross-overed speaker may result in a speaker that is 87dB/W @ 1m.
If you replace the 6.5" driver with a 12" driver with a sensitivity of 88dB/W @ 1m then the drive voltage requirement has not changed and with a bit of correction to the passive crossover will reproduce the same SPL as the unmodified speaker.
However, if you chose a higher sensitivity 12" (or bigger) driver, maybe 92dB/W @ 1m then the new speaker will have a bass/mid response that is around 4dB higher than the treble. The speaker will sound as though it had very much reduced treble output.
The way to solve this is to send a lower drive voltage to the high sensitivity Bass/Mid driver.
Soongsc, this is the complete opposite to what your post implied.
regards Andrew T.
Old 21st May 2012, 12:11 PM   #46
R.I.P.
this is complete nonsense. !!!!
regards Andrew T.
Old 21st May 2012, 12:13 PM   #47
R.I.P.
Originally Posted by bcmbob View Post
........... the addition of the Mundorf AG caps at C3 and C8, plus a larger transformer has given me all the deep, controlled and musical bottom end I can handle. With that combination the MyRefs do everything from shaking the house with pipe organ pedal notes to finely played bass lines in a jazz trio. The beauty of the MyRef approach, it's best feature is just letting what's being fed come through over the entire spectrum.
are these C3 & C8 the same as in the FE thread?
regards Andrew T.
Old 21st May 2012, 12:21 PM   #48
Yes Andrew, they are great for V1.2 through the FE. A bit expensive ~$30 each, but worth every penny.
Bob M.
Old 21st May 2012, 12:24 PM   #49
R.I.P.
has that just added 12700pennies to the cost of a 2ch amplifier?
regards Andrew T.
Old 21st May 2012, 12:34 PM   #50
Not bad speed for quick head calcs, Those big numbers help keep the world economy running.
I guess all things are relative - Check out the middle of this page Teflon Film and Tin Foil audio capacitors by V-Cap
BTW, I got mine from Parts Conexxion in Canada.
Bob M.
Mauro Penasa MyRef vs simple LM3886 circuitHide this!Advertise here!
Mauro Penasa MyRef RevC GainClone Mono Blocks apoopoo999 Swap Meet 6 29th July 2011 04:27 AM
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 17th October 2010 11:42 PM
Evolution Amplifier by Mauro Penasa Panelhead Chip Amps 14 22nd July 2010 09:56 AM
WTB: Mauro Penasa Ref C marginwalker Swap Meet 0 13th October 2007 05:28 PM
MY_REF EVOLUTION by MAURO PENASA goldkenn Chip Amps 8 25th September 2007 04:50 PM
