| Chip Amps Amplifiers based on integrated circuits |
#31 |
Thanks hurtz,
I've been flirting with the xonar cards since they came out. Unfortunately, all my extra cash has been diverted to amp building. I do have a M-Audio Delta 66 and a Delta 1010 that might be usable with the rightmark program. I downloaded it a couple weeks ago, but now that I have someone to guide me, I'll start trying to get my head around it. Thanks again.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#32 |
Reality first!
Hi Hurtz,
I realize now that maybe you want to see some measure of the orginal My_Ref to compare it to a Gainclone... Am I right? In the original My_Ref thread there are several measurements made by Mauro Penasa (the designer) and some of Soongsc. Read the attachment and from post #90 of the linked thread. From the attached document: Bandwith (tipical): 2Hz-70Khz Output power(±37V): 40W/8ohm – 56W/4ohm Damping Factor (8ohm): >200 (frequency and compensation depended) S/N 600ohm: >90 dB (compensation depended) THD e IMD (tipical), 20Hz-20Khz, 1-40W/8ohm: <0.05%
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#33 |
Thanks!
That was pretty much what I was looking for. Sadly though I can only test my builds using rmaa and have no fancy test-equipment for phase shift and such. Maybe when I finish my studies I'll have the budget to afford such things :-) In the meantime rmaa all the way ;-) Also I think there a quite a few microphones out there to measure output of the speakers but they are much more expensive than a simple sound-card. cheers! hurtz |
#34 |
Hey hurtz,
I may be in good shape. I see that one of the default devices in RMAA is the M-Box 2. I got a great deal on eBay for one of those several months ago. I don't know if the signal is as clean as the best xonar cards, but it puts me in the ballpark. I'll start setting up a test bed sometime next week.
#35 |
Bob how about that review you promised? Did you compared it to some boutique amps?
#36 |
Sadly, I'm going to have to push it off till Monday. I installed some Caddock resistors in a few positions a couple days ago and also want to change out two caps - C7 & C30 - to some top choice samples from Dario. It's also suggested to use an IsoTek burn-in process to get each cap (actually the entire system at each incremental change) close to optimum performance quickly and also determine which orientation sounds best. I decided it was worth the delay to get these last few adjustments completed.
Trust me, I'm as curious about the results/comparisons as anyone.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 19th May 2012 at 11:44 AM. |
#37 | |
cheers! hurtz |
#38 |
I think the MyRef can beat good Class A designs. I have compared against at least one, I certainly prefer the MyRef. General LM3886 design similar to the application note can be very good too. In my case, I have one of each that are under competition against each other. While taking turns to mod one to beat the other, I don't think I have a conclusion yet, but the MyRef may eventually win. The key issue how you get the power supply to work optimally with the circuit, which is not a small task.
Hear the real thing! |
#39 |
for bi-amped application(woofer+ fostex full range, say crossed at 250-300hz), will it make sense to use plain LM3886 circuit for woofer and MyRef for fullranger? the basic question here is in which freq.band MyRef excels?
#40 |
I would use the same amp for all bands unless the woofer is something like 12" or more.
| Mauro Penasa MyRef RevC GainClone Mono Blocks | apoopoo999 | Swap Meet | 6 | 29th July 2011 04:27 AM |
| my_ref revC group buy (Mauro Penasa LM3886 design) | schro20 | Group Buys | 650 | 17th October 2010 11:42 PM |
| Evolution Amplifier by Mauro Penasa | Panelhead | Chip Amps | 14 | 22nd July 2010 09:56 AM |
| WTB: Mauro Penasa Ref C | marginwalker | Swap Meet | 0 | 13th October 2007 05:28 PM |
| MY_REF EVOLUTION by MAURO PENASA | goldkenn | Chip Amps | 8 | 25th September 2007 04:50 PM |
| Page generated in 0.13553 seconds (100.00% PHP - 0% MySQL) with 10 queries |
