| Chip Amps Amplifiers based on integrated circuits |
#141 | |
Account Disabled
probably should be done under random noises with some concentration on the lower frequencies (a pink noise for example?). |
#142 | |
Account Disabled
I think it will be hard to argue, given the magnitude of the noise and its frequency distribution, that a reasonably decent amp with 50db psrr will suffer from an average PS whose fft looks like the one you presented. |
#143 | |
well Mesh, did u ever think why a simple op amp circuit doesnt need a 10000uf filter caps ? thats because the size of the filter caps is depended on power output .Most chip ams are rated at < 50W so less capacitance needed , plus chip amps got good psrr and low "on" current . One more reason : those chip amps are intended for applications that require small space ,thats why in the application notes u see small filter caps , this is the minimum size required . there is nothing wrong with using large filter caps for any amp but too much wount do any good eather . |
| Page generated in 0.11781 seconds (46.35% PHP - 53.65% MySQL) with 11 queries |
