5.1 ch using TDA1558Q
Old 7th May 2012, 02:06 PM   #1
Hakimi is offline Hakimi  Malaysia
Talking 5.1 ch using TDA1558Q
I saw output of my computer is, Front LR, Rear LR, and CenterSub.
my Creative usb sound card
Is it possible i built 3 set of TDA1558Q (2ch each) and connected to computer. and drive the 5.1ch home theatre speaker ?
and using this potentiometer as volume control
Panel Mount PCB 6xStepx50k Linear 50k Pots Rotary Volume Tone Potentiometer,P001 | eBay
Any one does this?
Old 7th May 2012, 02:54 PM   #2
AudioSan is offline AudioSan  Norway
its no problem. but i guess i will need a sub filter too.
and use a Log pot insted of Lin pot.
i'm building a 5.1ch plate amp with LM3886 and a UcD400 now.
Old 7th May 2012, 03:04 PM   #3
does SUB output from card is CLEAN bass ? doesn't need filter..?
Old 7th May 2012, 03:09 PM   #4
i doubt the sub out has a filter.
Old 7th May 2012, 05:11 PM   #5
Arty is offline Arty
it is based on software. Some do have the "bass redirect" ability (if i remember 1st gen audigy called it like this), and most do not have this option.
Better to have that filter.
Old 7th May 2012, 05:39 PM   #6
or find a x-over plugin for the sound card. don't know if it exist. but one can check
Old 7th May 2012, 09:47 PM   #7
hurtz is offline hurtz  Germany
To consider:
-If the subwoofer isn't DIY it will most likely be an active subwoofer.
-Usually if playing 5.1 content the lfe channel is already filtered.
-Many Subwoofers have a crossover included, sometimes with adjustable cutoff.
-If the subwoofer is used to enhance the lower spectrum of your other speakers it is desireable to adjust cutoff frequency manually, either by the subwoofer or in software on the soundcard or my preferred method in the media player directly (mplayer).
cheers,
hurtz
Old 7th May 2012, 11:51 PM   #8
ONE thing to consider.
so not a finnished product.
LFE has NO X-over.
5.1 ch using TDA1558QHide this!Advertise here!
SPDIF out from DVD/BD player to 2-CH DAC instead Multi-CH Processor - what happes ? tiefbassuebertr Digital Source 5 5th November 2011 02:50 PM
Temp Variations CH to CH Zero Cool Everything Else 0 4th February 2007 02:25 PM
TDA1558Q help gompka Chip Amps 3 3rd May 2006 09:50 PM
bridge a 4 ch amp into 3 ch? batonrye Car Audio 8 17th August 2004 11:37 PM
TDA1558Q How much RMS ? Dj BASS AMP Chip Amps 1 9th August 2004 01:31 AM
