Old 1st May 2012, 06:16 AM   #1
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh
Default Stereo LM1875 / TDA2050 PCB with Power Supply
Hi friends,
I am planning to make a Stereo PCB for LM1875 / TDA2050 with Power Supply. Just finished with initial PCB routing. The power supply routing will be converted to planes and there will be a central ground plane.
My Blog
Old 1st May 2012, 09:55 AM   #2
Bone is offline Bone  United Kingdom
Why does the right hand amplifier not have wide power traces on pins 3 & 5 like the left hand one? And why the different zig zags on the signal earths
Old 1st May 2012, 10:00 AM   #3
I count 4 terminals on the ground trace !
Which one are you planning to use? Note which one.
I see a gap in the trace tapping points for the PSU decoupling caps. Inside that gap are two terminals and two traces going elsewhere.
Where did you pick up these PCB design tips?
Old 1st May 2012, 10:15 AM   #4
I made planes now as shown. Trying to fine tune the ground plane.
Since its a single side PCB, the +- supply lines needed to be connect by jumper wires, VP_out <-> VP_in and VN_out <-> VN_in.
And the zig zag trace connects signal ground to main ground, its a kind of experiment only, i expect it to simulate 1Ohm ground resister. But i hope it doesn't cause any inductive effect. (Mr Andrew, kindly give your opinion on this). And the "one" you mentioned, i plan to make that at GND terminal connector, which also connects to transformer's center tap.
My Blog
Old 1st May 2012, 10:18 AM   #5
I have already offered comment, but you seem to have overlooked it.
Old 1st May 2012, 10:28 AM   #6
The zig zag trace does not simulate a resistor but an inductor, which you preferably avoid in ground traces.
Where do you connect the transformers center tap?
You are not really using electrolytics for the RC circuits at the amp outputs?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 1st May 2012, 10:40 AM   #7
@ pacificblue
Then will widening the zigzag trace will inductance to minimum level at the same time providing a longer trace for signal ground. The only idea is to raise the signal ground from main ground without using any resister. Is it acceptable.
And the transformer canter tap will connect to GND header (just above the bridge rectifier). I am using 0.1uF at output zobal, ya, that can be converted to non-polarized cap.
And Mr. AndrewT, I got your point, but it will be more easy to apply that in double sided design. In my place the PCB fab cost doubles for Double sided PCB, and that's why i have difficulty to terminate all ground traces to a single point in single side PCB.
My Blog
Old 1st May 2012, 11:26 AM   #8
Originally Posted by kuldeepsingh View Post
............but it will be more easy to apply that in double sided design. In my place the PCB fab cost doubles for Double sided PCB, and that's why i have difficulty to terminate all ground traces to a single point in single side PCB.
It's your single sided that is wrong.
Don't complicate it with double sided. Learn how to do single sided first.
Old 1st May 2012, 12:09 PM   #9
Then please guide me a little. I havn't taken any professional course in PCB routing or in electronics . can you edit my uploaded PCB schematic picture in paint & just give me a visual clue :]
My Blog
Old 1st May 2012, 12:44 PM   #10
Widening it won't make a big difference for the inductance. Ground traces should not be meandering.
A 0,254 mm wide 35 µm thick trace will approximately have 1 Ohm for every 50 cm of length. There should only be one signal ground for both channels.
LM1875 power supply Chricket Chip Amps 29 30th September 2011 02:17 PM
Power output test LM1875, TDA2050, TDA2040 johnr66 Chip Amps 5 6th May 2011 06:28 PM
LM1875, TDA2050 on 2 Ohms johnr66 Chip Amps 6 18th February 2010 01:55 PM
LM1875 as substitute for TDA2050 suzyj Chip Amps 8 1st June 2008 07:26 PM
Copyright ©1999-2013 diyAudio
