8-Channel Gainclone Amplifier
I'm building this multi-amp to drive my DIY speakers. They are 4-way active dipole prototypes with MiniDSP crossovers.
Currently they are powered by 8-channel ClassD amps. They're great except not liking the 2 ohms nominal tweeter impedance (paralleled, the back tweeters are not visible). I did a study on the distortion between gainclone and ClassD before at the acoustic output here.
The 8-channels gainclone amps are based on AudioSector 4780 kit:
As seen above, I'm using no-fuss components sourced from local provider here (Jaycar). I did the effort, however, to painstakingly measure the resistors individually before using it.
Class D amps are especially happy with low impedances. The trouble at the top end lies in the passive low pass they need to convert the PWM output back to a sine wave. The filter will only work perfectly at one specific impedance. The solutions are either to adapt the filter to the load the actual speakers pose or to linearise the speaker load to the impedance the filter was designed for.
Often the amp designers assume that the load is resistive for the filter design. The actual frequency-dependant impedance of a real loudspeaker will then warp the frequency response in an undesired manner. That is why many people report that class D amps sound harsh, edgy or even piercing. An impedance linearisation for the tweeter solves that issue.
The amps are easy enough to wire, although not as easy as ClassD ;)
What is critical is the star grounding. If done incorrectly the output will hummmmmmmm...
You are correct, but I don't think Sure TA2050 which are harsh. In fact my study above proved the distortion is the same as gainclone. Yes the frequency droop can be fixed by changing the output filter. But in my case it's much simpler to correct it at the DSP.
It looks like a great project! I would love to build a multichannel amp one day for my active 3-way speaker. My skills are not up to point where I'm comfortable to tinker around with things that run on mains voltage. For the moment I decided to buy a used multichannel receiver and work with that. I must say though the sound quality on the lower and mid-end receivers is unacceptable.
I hope you do a thorough write up on this one, I enjoy reading about your projects.
How many toroids are you planning to use, they can get pretty big and heavy as power requirements grow.
Would you please go over correct grounding practices in detail (again)?
How do plan to handle volume control? Multichannel volume control in the amp should give the best gain structure.
Here you can see 160VA, 25v-0-25v Toroidal transformer that I use.
Initially I was just trying it and planned for a bigger one (300VA). However there is no problems using it driving the speakers to deafening level. It is well known that dipoles are very easy speakers to drive (e.g. the woofers operate at their inherent Fs). Hence I keep it.
The cabling could be much neater, but I prefer keeping them long, in case another swap with ClassD is needed :cool:
You can compare the look with ClassD:
Hey Andi, nice looking speakers. I came across this thread because I'm having the same problem as you (although with a different cause, I'm sure). My 4 way dipoles also have an audible hiss, which after living with for a number of months, has to go.
For me, the noise is coming from my miniDSP unit (which I think you're also using). My problem is that I need my volume control to be after the miniDSP, not before it. What do you use?
I like your amp setup. I built 8 channels of custom amps, point to point, and it is way too big, way too complicated, expensive, and way more power than I need. I really should have gone with GC amps...
