Need help with buzzing amplifier - diyAudio
Old 30th April 2012, 03:21 PM   #1
maurycy is offline maurycy  United States
Default Need help with buzzing amplifier
I have built a guitar amplifier based on the Hitachi HA13118 chip. Unfortunately, it has a buzz. It is not hum but a clear buzz that gets louder with the volume. That's even without the guitar attached.
Here is a schematic:
guitar amp schematic
The power cord going to the trafo is two prong. Case is plastic and everything is basically attached as the schematic shows. The whole amplifier section is on a PCB so only in, out and power connections go to and from the board.
Old 30th April 2012, 05:22 PM   #2
Put a 22K resistor across C11. Any wattage any tolerance!
Old 1st May 2012, 01:37 AM   #3
I guess there may be something wrong with the amp or the wiring as adding 22K resistor did not help at all. It looks like I will have to pull the board out and test it outside of the amp.
There is also big thump when I switch the power off.
Old 1st May 2012, 02:46 AM   #4
Send a message via AIM to DigitalJunkie
Try running it from a battery,and see if the hum clears up. I'm wondering about your power supply layout and wiring. Got a pic of the amp?
Old 1st May 2012, 09:56 AM   #5
Have you downloaded the Hitachi datasheet?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st May 2012, 12:37 PM   #6
Here is a picture of the amplifier: picture. Not a great one and kinda hard to read what's inside. The PCB is a kit and only trafo, smoothing capacitors and diode bridge is outside of the amp board.
Andrew: Yes, I have downloaded the datasheet but with my limited knowledge, all the numbers and charts do not really tell me much. If I knew how to build a hum/buzz free amplifier, I wouldn't be buying a kit.
Old 1st May 2012, 12:58 PM   #7
Compare the schematic in post1 to the schematic in the datasheet.
I think they are probably different.
regards Andrew T.
Old 1st May 2012, 01:19 PM   #8
Will do. The amp was built from the kit though. I wasn't expecting this amp to be hum/buzz free with 10% THD at full power but the current buzz is louder than my refrigerator.
Old 2nd May 2012, 05:50 PM   #9
Looking at your picture and the 22K resistor results, lets go a step farther. Dose this kit expect plus, minus and ground rails?
I see a full wave bridge rectifier and two sets of capacitors, which would imply a ground is needed. As the transformer is not center tapped, it looks like you have attached the wires between the filter capacitor as ground. If that is the case remove one of the transformer wires from the bridge rectifier and attach it to the ground between the capacitors.
Old 2nd May 2012, 05:55 PM   #10
From what I can tell only plus and minus DC. I was curious if there should be a ground but it is not on the schematic. The kit's description calls for a well filtered power supply to reduce hum but mine is loudly buzzing not humming.
I still have to pull the amp out and connect it to the 12V battery that I have to see if the buzz goes away.
buzzing transformers.... rtate Solid State 38 7th April 2008 11:33 AM
Kenwood KA-9100 Amplifier Buzzing trustchild Solid State 6 4th December 2007 10:54 AM
Rotel amplifier buzzing, please help lt cdr data Solid State 10 14th November 2006 12:14 PM
My amplifier makes a buzzing noise Jimmy154 Solid State 7 25th October 2002 04:27 AM
Copyright 1999-2017 diyAudio
