diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Is this method of heat sinking a good idea? N00b question ahead... (http://www.diyaudio.com/forums/chip-amps/211795-method-heat-sinking-good-idea-n00b-question-ahead.html)
mgcasella 29th April 2012 09:34 PM
Hey everyone I finally got a job and – even though I’m severely under-employed – it’s better than nothing and now I have a small income with which to work on my projects :)
The following is my beloved Ibanez Toneblaster 25R guitar amp. I got it used from a friend and it is definitely a great bang-for-your-buck amp for heavy music (especially when you trash the stock speaker and hook it up to a decent cab).
http://i204.photobucket.com/albums/b...ck-of-pots.jpg
http://i204.photobucket.com/albums/b...r/Gut-shot.jpg
As you can see, the method Ibanez used to heat sink the chips is to hook them both up to a metal plate. This metal plate supports the PCB and is attached to the bottom of the chassis. Also, it looks as though some things have been grounded by being attached to this plate.
Here are my questions:
1. Generally speaking, is this a good method for heat sinking?
2. If not, why? Does it denigrate the sound quality?
3. If not, is there a way I could improve it?
I currently have some eBay bucks that will expire in a few days and was thinking I could buy this in order to improve the Toneblaster. Let me know what you all think – I’m looking forward to it :)
Conrad Hoffman 30th April 2012 12:12 AM
A couple thoughts- if the chassis is made out of steel, having the heat sink screwed to the chassis accomplishes almost nothing. Steel doesn't transmit heat well, so it doesn't spread and doesn't add much to the area of the heat sink. The aluminum heat sink is good as far as it goes, but could probably be better if it had some fins for more surface area. Now, if the devices are decently attached to the sink, and if the sink isn't getting hot, don't worry about it; it's entirely adequate. If it does get hot, you probably won't improve or change the sound much, but improving the heat sinking will improve the reliability. Maybe. Those little eBay sinks are too small to accomplish much of anything. If I were going to "hot rod" this, I'd make a new heat sink out of a large finned aluminum extrusion. You could also epoxy an extra finned piece to the existing sink if you keep the epoxy joint thin and use a thermally conducting epoxy. That might be the most elegant solution.
AndrewT 30th April 2012 09:58 AM
Check the device temperatures as Con has advised.
bcmbob 30th April 2012 11:16 AM
1 Attachment(s)
Home Depot, True Value and the like have a large selection of "L" and square aluminum in several thicknesses. A long chunk could attach to the chips and span the chassis. You could still use those little HS something like the pic.
Attachment 279853
mgcasella 1st May 2012 11:50 PM
Hey thanks for the advice and comments everyone :)
I have a feeling the chassis and plate is made of aluminum, as opposed to steel, since the amp wasn't very expensive. However:
1. How can I effectively check the temperature of the chips?
2. Is there a specific piece of equipment I should use? If so, where can I get it?
3. What should be the appropriate temperature of these chips?
gootee 2nd May 2012 12:41 AM
Checking chip temperature: If you put your fingertip on the exposed body of the chip and your skin instantly blisters or smokes, or if you can't hold your finger against it for more than one second, then it's probably too hot. Ideally, you would want to be able to hold your finger against it indefinitely, but five seconds might be OK. Or I guess maybe you could use some sort of thermometer. Either way, you're only talking about the case temperature, not the junction or die temperature (inside the chip) that is probably in the specs.
If it's "too hot" even with a good heatsink, then you are probably either running it too hard or there's a high-frequency oscillation.
bcmbob 2nd May 2012 01:02 AM
Non-Contact Infrared Laser Thermometer
Works great and can be found even cheaper at some tool outlets.
AndrewT 2nd May 2012 10:28 AM
Originally Posted by mgcasella (Post 3008354)
...................However:
1. How can I effectively check the temperature of the chips?..................
Mothers use their elbow, but I'll guess your elbow won't fit. Try the end/tip of your pinkie finger.
AndrewT 2nd May 2012 10:34 AM
there is another Thread where the user of this "laser guided" infra red temperature meter swore blind that it was accurate and chastised us for even questioning his temperature measuring method. A few weeks later he came back and announced he was now measuring a much higher and probably more accurate value and now realised his absolutely fantastic laser meter was telling him lies.
Well that not quite how he put it, but it is what is implied in his post.
It must have taken twenty to thirty posts trying to get him to calibrate his temperature measuring method. He would not accept that his method even needed calibration, nor that the calibration would need to be done for every new surface he was trying to measure.
The message from all of this.
You must understand what you need and what you need to do to get reasonable results from any measuring system.
franzm 2nd May 2012 10:45 AM
Those infrared thermometers are very inaccurate because of the unknown value of the emissivity Emissivity - Wikipedia, the free encyclopedia
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
