MAX13330 Headphone Amp - diyAudio
Old 28th April 2012, 08:31 AM   #1
Kamuy is offline Kamuy  United States
Location: Curled up inside these nice warm power MOSFET heatsinks.
Default MAX13330 Headphone Amp
This is my first attempt at trying to make my own headphone amp based on information in datasheets alone. I'm not sure if this schematic is correct, or what could be added/removed to improve it, specifically dealing with virtual grounds.
The LM386 and summer are for a visualizer I'm planning to build into the amp.
Here is the datasheet for the MAX13330: http://datasheets.maxim-ic.com/en/ds...0-MAX13331.pdf
Advice? Opinions?
Old 18th May 2012, 03:00 AM   #2
Hey Kamuy,
'looks like a neat project! I thought at first that U2 might clip on the negative side, but looking quickly at the datasheet for the lm386 it seems it self-aligns the output between the rails, is that right? Pretty cool little chip.
What kind of display were you thinking of making? Keep up the good work!
Jim
Old 20th May 2012, 08:15 AM   #3
It's pretty much a requirement for any chip that does not generate its own negative supply, otherwise you wouldn't get any kind of decent output amplitude. If you're interested in how that works, I've looked at it here.
The venerable LM386 should be good enough for driving a viz.
My new el34 + 12ax7 VCT amp. (Need Ideas For my first headphone vacuum tube amp Too~) briansune Tubes / Valves 10 12th July 2013 05:33 PM
Tube amp OPT for Headphone Amp? (impedance matching question) rongon Tubes / Valves 21 3rd January 2012 04:20 AM
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 30 10th September 2011 02:05 AM
Poor power output, op amp based headphone amp. dannybeckett Solid State 13 27th September 2010 08:31 PM
SDS Labs Headphone amp. Anyone built it? can it be converted to a power amp? JCoffey Headphone Systems 1 30th May 2003 12:11 PM
Copyright 1999-2017 diyAudio
