Old 5th October 2003, 02:25 PM   #1
Default Lm1875
I don't know too much about heatsinks, other than they take heat off of chips. Is the small heatsink below sufficient for the LM1875?
Old 5th October 2003, 02:31 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
No, far from that. Use a proper heatsink that is able to keep the chip at a normal temperature at full load.
It's only audio
Old 5th October 2003, 02:37 PM   #3
How about this?
Old 5th October 2003, 04:18 PM   #4
jean-paul's Avatar
Still too small.
It's only audio
Old 5th October 2003, 04:31 PM   #5
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Re: Lm1875
Here's the datasheet for the LM1875.
http://www.national.com/ds/LM/LM1875.pdf
There's a lot of good info in it regarding heatsinks.
Search this forum as well. There are many threads talking about calculating them.
This is one example: http://www.diyaudio.com/forums/showt...ht=#post101358
/Hugo
Old 6th October 2003, 03:27 AM   #6
I have the datasheet, but all the equations and info about heatsinks make no sense to me. Can anybody explain to me some basic things about them?
My project is a surround sound computer speaker system.
Thanks, Mike
Old 7th October 2003, 06:44 AM   #7
just get 1 about the size of a couple of decks of playing cards
Old 7th October 2003, 01:39 PM   #8
JCoffey is offline JCoffey  United States
Or a heatsink from a PentiumII processor. My LM7886 integrated once I took it apart has a heatsink that size that both chips are attached to. I was kinda shocked, but it's never gotten too hot, so the LM1875's shouldnt need any more than that. I have access to quite a few of them here at work, since we're pulling all of our old PII pcs.
Old 7th October 2003, 03:55 PM   #9
jean-paul's Avatar
That's better.
It's only audio
Old 8th October 2003, 02:21 AM   #10
so, this is a little overkill, right? i mean, it can keep a 3886 cool... or am i wrong. If you cant read the ruler, it is 4 and 1/8 inch wide, about 2.5 inches deep and a little over 3/4 inch tall.
LM1875 PCB, Which To Use Paswa Chip Amps 238 1st November 2011 01:02 PM
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 04:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 03:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 04:28 AM
Page generated in 0.10459 seconds (78.26% PHP - 21.74% MySQL) with 11 queries
