| Chip Amps Amplifiers based on integrated circuits |
#11 |
soundNERD, the heatsink you refer to may be spread out over the dimensions you quoted, but that is nowhere near big enough. You need a heatsink that has a solid base and fins coming out of it, there needs to be alot more solid metal and surface area for the heat to dissipate than the sink you posted a picture of. You probably won't find heatsinks big enough at digikey or the likes, nor many local electronics stores, try looking at metal shops or the best in my opinion, surplus stores.
#12 |
Aluminum plate 3 x 6 will do.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 |
But how think a plate? If you use 1mm think Al, I doubt that'd be enough.
A small heatsink or a (relatively) think plate would work fine for you, just don't use anything that's stamped steel, you'll just toast your devices. |
#14 |
1/8 or 1/4 should work fine. It may get warm, but shouldn't be too hot.
#15 |
Sorry. Yet again, I forgot to attach the picture. Here it is.
| LM1875 PCB, Which To Use | Paswa | Chip Amps | 238 | 1st November 2011 12:02 PM |
| LM1875...how low can you go? | Gcollier | Chip Amps | 7 | 6th May 2010 03:43 AM |
| How hot does an LM1875 get? | Dominique | Chip Amps | 15 | 23rd January 2007 02:13 AM |
| lm1875 | siemensc65 | Chip Amps | 4 | 23rd May 2006 03:28 AM |
| Page generated in 0.07368 seconds (71.21% PHP - 28.79% MySQL) with 11 queries |
