Noob needs advice Noob needs advice - diyAudio
Noob needs advice
Noob needs advice
Old 22nd April 2012, 04:01 PM   #1
jwhisl is offline jwhisl  United States
Default Noob needs advice
Hello. Im new to the forum but I have been wanting to build a desktop amplifier for a 2.1 setup. I have been eyeing the Yuanjing tda7294/7293 amplifier on ebay. The seller says it puts out descent amount of power (2x80W+160W). The only thing I dont like about it are all the control knobs on the front. I really don't need independent left and right volume knobs. Is anyone familiar with this amplifier and does anyone know if there is a way to use a another board to control the amp (Main vol, sub vol, treble, pwr)? I don't know anything about this amp except what I read in the ad. Thanks
ebay ad: http://www.ebay.com/itm/2-1-Channel-...item3cb5f5090a
Old 22nd April 2012, 09:13 PM   #2
I just reread the ad and it does only have one main volume knob. I still wouldn't mind knowing if anyone here is familiar with these. I'm basically wanting to build something like the Lepai 838.
Old 23rd April 2012, 10:17 AM   #3
Ask the Seller for all the details.
That will confirm the customer support you can expect after you have bought the item.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd April 2012, 07:47 PM   #4
pacificblue is offline pacificblue  Germany
Lepai:
- 1x12V 24 VA power supply.
- 3x20 W into 4 Ohm promised, but only possible with a different power supply.
- complete amp.
Yuanjing:
- split power supply, which you need to calculate with the help of the datasheet.
- 2x80 W + 1x160 W into unknown impedance that take enormous heatsinks or the use of class H.
- amp PCB lacking power supply, case, heatsink, wires, connectors, etc.
- not likely to fit on the desktop, when finished.
The obvious thing both offers have in common is that they can be bought cheaper than the parts they are made from.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Noob needs adviceHide this!Advertise here!
Noob needs woofer advice =D spellwords Subwoofers 12 22nd August 2011 09:32 PM
Ambitious Noob looking for advice. mental2k Chip Amps 5 22nd July 2011 04:47 AM
Noob looking for some advice MrBurd Tubes / Valves 13 18th June 2011 06:29 PM
Copyright ©1999-2017 diyAudio
