L4780 bridged or parallel into 8Ω sub, use L + R signals? - diyAudio
Old 20th April 2012, 08:37 AM   #1
ZLyzen is offline ZLyzen  United States
Default L4780 bridged or parallel into 8Ω sub, use L + R signals?
I've done some reading about this but nothing really matched up to my situation
I will be running a l4780 in either a bridged or parallel configuration for a 8Ω sub. It takes 80wrms/160wpeak
Anyways, if my toroid is good on voltage should I be running this bridged to benefit from the current? wouldn't this then treat my 8Ω like a 4Ω?
also, can the inputs (since there are 2) be the left and the right so they are summed for the mono subwoofer? Is this common practice?
-Zack
Old 20th April 2012, 09:02 AM   #2
If you run it bridged each amp section will see a 4ohm load.
If you run it in a paralleled configuration then each amp section effectively see it as a16 ohm load.
Depending on what your power supply voltage is will determine which configuration will work best for and what power levels you are trying to reach.
So more information is required to determine as to what you need, namely what is the power supply voltage that you are planning on using.
And the type configuration that you are planning.
It is sometims practiced to sum the two channels together for sub signals, But should only be done in the preamp stage if you are using a bridged configuration as would be done if using a single amp.
jer
Bridged/Parallel LM3886 cloud85 Chip Amps 7 24th August 2011 04:18 PM
Parallel and Bridged question? portreathbeach Chip Amps 6 5th August 2011 03:35 AM
Parallel or Bridged 100watter amt Chip Amps 23 30th November 2003 02:05 AM
ZenV4 in parallel (not bridged) paulb Pass Labs 2 1st October 2002 01:57 AM
Copyright 1999-2017 diyAudio
