Anyone with any experience or technical knowledge of this PCB - diyAudio
Old 18th April 2012, 08:33 PM   #1
Default Anyone with any experience or technical knowledge of this PCB
Hi All,
New to the forum and I must say, the knowledge here is amazing! I wish I had known about this forum a long long time ago!
On to the topic at hand:
Does anyone have advanced knowledge of this board:
LM3886 x2 + opamp preamplifier 68W 4 ohm amplifier PCB | eBay
I have seen some folks post positive remarks about Jims Audio on Ebay and this board seems like a good fit for my application.
My speaker cabinet is a stereo cabinet with two full range speakers, so no crossovers are needed.
I already have a 28.4v secondary transformer so that is taken care of. I'll get the rest of everything else from Mouser or other known supplier.
The auction info has very little info but I was mainly wondering what the maximum input level would be. My application is not really hifi in nature so garden variety opamps will suffice like the NE5532 mentioned.
I have already built an XY Power amp and it has had some issues. Will post about that in another thread when I have the chance to get some better pictures.
Thanks in advance,
Mick
Old 20th April 2012, 12:17 AM   #2
Minion is offline Minion  Canada
You will need a Transformer that either has 2 secondaries or is center tapped so a single 28v winding won"t do you any good .....
A dual 28v or center tapped 56v transformer will be too high of a voltage for the Chip .....
28v will get you about 42v DC which is a bit high for the LM3886 , I wouldn"t go any higher than +/-35v DC into 8 ohms or +/-28v into 4 ohms ......
I would suggest you look for a transformer that has 24v 0v 24v for an amp that drives 8 ohms or 20v 0v 20v for an amp driving 4 ohms ......
PS: the Ebay add is misleading .... first it says it runs off of a 28v 0v 28v transformer which is really the very upper limits of the chip and risks frying the chip if your house voltage spikes , and it also gives the impression that you can run it into 4 ohm loads at that voltage which is totally false , the chip can not drive 4 ohms useing a 28v 0v 28v transformer.....
Cheers
Old 20th April 2012, 04:28 PM   #3
Cheers
Thanks Minion.
My apologies, I was not clear in my original post.. my current transformer is 28-0-28 and I am willing to get a 24-0-24 to help prevent the risk of toasting the amp.
As to dealing with Jims Audio... I can't say enough good things... Ordered two boards... parts list and schematic were sent shortly after... Several questions were answered quickly... I will certianly purchase from Jims Audio again!
Anyone with knowledge of the 12b4? surfstu Tubes / Valves 7 15th May 2009 06:51 AM
More and more knowledge zcqiang Introductions 3 13th June 2007 05:19 AM
Does anybody have any knowledge of this jamikl Full Range 7 2nd April 2007 09:22 AM
Copyright 1999-2017 diyAudio
