First amp. Need lots of help - diyAudio
Old 17th April 2012, 09:02 AM   #1
Talking First amp. Need lots of help
Supplies:
antec earthwatts 430w atx psu (12v 360w max)
3x tda2030
tda6108jf
tda7057aq
ta8211ah
la6500
tda2822
dual 7173k on pcb from old car stereo
lots of enclosures, wire, speakers, connectors and not much knowledge but lots of determination haha.
Help me?
Old 17th April 2012, 10:58 AM   #2
Preferably around 60w
Old 17th April 2012, 12:02 PM   #3
tda2030 uses +-6Vdc to +-22Vdc. It is not suitable for a 12Vdc supply.
12Vdc supply limits the absolute maximum output from a Power Amplifier to ~3Vac.
3Vac into 8r0 is ~ 1.1W
3Vac into 4r0 is ~ 2.2W
3Vac into 2r0 is ~ 4.5W
3Vac into 1r0 is ~ 9W
Which of those chips can drive an 8ohm speaker?
Which of those chips can drive an 4ohm speaker?
Which of those chips can drive an 2ohm speaker?
Which of those chips can drive an 1ohm speaker?
If you bridge a pair of Power Amplifiers then the bridged pair can drive a double value load resistance to double the power.
i.e. use a pair of 30W into 4r0 power amps in bridge mode and you have a 60W into 8r0 power amp. Note that both sets of amplifiers deliver the same total power of 60W. You have not gained any extra power.
Now let's assume one of your selected chipamps can drive a 2ohms speaker. Then in bridged mode it can drive a 4ohms speaker.
The absolute maximum power available from 12Vdc is ~4.5W into 2r0.
The absolute maximum power from a bridged pair will be ~9W into 4r0. i.e. you may have created a 9W into 4ohms amplifier.
You cannot get anywhere near your 60W target with chipamps from a 12Vdc supply.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th April 2012, 12:59 PM   #4
Damn thanks that was alot to help.
Well It doesnt have to be 60w, what about 40? I think i might still have the transformer that got from the same system I got 2030s from.
Im sure I have a pair of 4ohm speakers somewere around here haha..
Oh and last thing, My psu has a -12v rail but with minimal ratings
Old 17th April 2012, 06:01 PM   #5
johnr66 is offline johnr66  United States
You could get 36 watts max from the TDA2030A if you bridge them and have an adequate power supply. The computer supply will not work. If you want more power, I'd suggest an LM3886 kit if this is your first amp. You could build an 18 watt amp with a single TDA2030A if you want to tackle the component layout yourself. Use a bulb tester so you don't blow anything up.
Adcoms with lots of DC offset. Lots! ben62670 Solid State 72 28th September 2014 03:02 AM
lots and lots of broken Vifa D26NC55 tweeters! gripracer Swap Meet 0 3rd October 2010 11:11 PM
Reckhorn A-400 Subwoofer Amp, lots of features! sbrtoy Swap Meet 2 19th April 2008 12:22 AM
Wanted (UK): big amp to run lots of 18"s mr_tim_e Swap Meet 0 23rd April 2007 11:35 AM
Alpine amp plays fine but needs lots of signal input? spooney Car Audio 2 20th January 2007 08:20 AM
Copyright 1999-2017 diyAudio
