Virtual breadboard of a mono CMOY. Have a few questions
Old 1st April 2012, 05:05 AM   #1
alfa147x is offline alfa147x  United States
Default Virtual breadboard of a mono CMOY. Have a few questions
Based off of this PDF
How does the breadboard look?
I can't figure out where all the "ground" symbols are actually connected to. Any ideas?
Old 1st April 2012, 10:56 AM   #2
Create an Audio Ground for the amplifier.
Create a Signal Ground for the input.
The junction between the batteries is your Zero Volts.
Join all these grounds together at the Audio Ground.
regards Andrew T.
Old 1st April 2012, 12:29 PM   #3
epicyclic is offline epicyclic  United Kingdom
Hi
Theres no connection from the centre of the batteries to centre of C4 and
C5
Edited some comments as believe i was misreading the small print on the PDF
Old 1st April 2012, 02:17 PM   #4
pacificblue is offline pacificblue  Germany
Compare your schematic to the original. Think about S2 in your schematic again and what happens, when you flip it. Correct your schematic accordingly. Then start the breadboard layout again.
All the ground symbols are connected to each other. It can make sense to connect them groupwise and then join the groups, as Andrew suggested, but that's probably breaking a fly on the wheel in this context.
Don't create a ground between the batteries. Batteries may discharge at different rates or may come at different charge levels already and your ground would not be reliably at half supply. It is better to stick to the original schematic, create a single supply and a virtual ground.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 1st April 2012, 05:37 PM   #5
So once I create the virtual ground I can then connect anything that calls for a ground to it? Does this also work for the return from the headphone/speaker?
Thanks for the help. I don't know why I forgot to create the virtual ground on the power side. I'm using fritzing and while it was easy it was a bit of learning curve.
Thanks again!
Old 1st April 2012, 06:29 PM   #6
I've added the virtual ground that I forgot.
Also what does S2 stand for?
Old 1st April 2012, 07:53 PM   #7
AlexQS is offline AlexQS  United States
It's hard for me to read "S2" on your diagram. Are you talking about the top left corner of your diagram. That looks like an on/off power switch in line with the batteries,.... I can't see for sure if that says "S2" "B2" or "82" but it's a switch in the top left.
Old 1st April 2012, 08:05 PM   #8
Here is a link to the full size image for the diagram:
http://i.imgur.com/zDlAR.png
Oh. I was talking about this:
Old 1st April 2012, 08:21 PM   #9
Ahh,.. I see. I do pay attention to Pacificblue, has more experience than I do.
Old 1st April 2012, 09:30 PM   #10
I'm paying attention to everyone. Everyone has more experience than I do lol
Here is my attempt at dual mono op amp setup:
Link to larger version
I based it off of the OPA637/627 I'm not 100% those are the chips I want to use.
How does that diagram look? I've placed an X on the extra capacitor I've placed.
I've read the datasheet on the OPA637 multiple times but I can't seem to figure out how to decipher it's ideal power requirements are . I was able to figure out the max is 36 and the min is 9.
My next step is to figure out how to supply about 18 volts @ 13 mA to each chip. I'm assuming that would be the ideal amount per chip.
Thanks for the help!
Virtual breadboard of a mono CMOY. Have a few questionsHide this!Advertise here!
Using 2 MC34063 for CMOY virtual ground KungFuPanda Chip Amps 4 21st February 2012 08:44 PM
Cmoy Virtual Ground Setup jtavrisov Headphone Systems 4 9th August 2011 08:00 PM
Audio Newbie Questions on Virtual Surround vonzevon Everything Else 3 21st April 2007 07:00 AM
6L6 mono amp questions rickl Tubes / Valves 27 10th November 2005 04:57 AM
Dual mono questions revell Chip Amps 0 27th August 2004 04:41 PM
