Virtual breadboard of a mono CMOY. Have a few questions Virtual breadboard of a mono CMOY. Have a few questions - Page 2 - diyAudio
Old 2nd April 2012, 06:29 PM   #11
pacificblue is offline pacificblue  Germany
A dual mono headphone amp? So you have a headphone with separate connectors for each ear? Or is it going to be a mono amp for two listeners?
Whatever it is, build the original circuit first. Use all components with their original values. Don't skip the k in the resistor values. Don't add capacitors arbitrarily. Follow the instructions on the CMoy website.
When the original circuit is up and running you can think about tweaking it.
Hint 1 on the power supply question: Your schematic contains two batteries which supply 18 V. The amp will draw the current it needs on its own. No need to worry about the mA.
Hint 2: S2 is a switch. If you connect it the way it is drawn on your schematic, your amp will never work. If you connect it right however, the amp will get 18 V from the batteries.
When you got it working on batteries, investigate how to build a mains-fed power supply. HeadWize - Project: Designing an Opamp Headphone Amplifier (A HeadWize Design Series Paper) is a good source on the topic. Be aware that at some point during that process you will be working with mains voltage and that can be dangerous.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 2nd April 2012, 06:37 PM   #12
alfa147x is offline alfa147x  United States
Tanks for your help.
I want to be able to hook up my balanced headphones up to it. The goal is to build simply a dual CMoy.
I'll order parts to build a single CMoy then adjust it as needed to do dual mono. I wanted to start with OpAmps then move on to building a Class A amp.
Thanks for the link. How do you read a datasheet for a OpAmp to understand what it needs? I somewhat understand the power portion of it but i'm confused where the audio comes in. I don't really understand how to figure out what resistors and capacitors are needed for that portion. As well as going out from the opamp to the headphones.
If you could just give me what those two portions are called my google searching abilities will be able to take over from there
Thanks again,
Alfa
Old 3rd April 2012, 09:17 AM   #13
read PASS, ESP, Decibel Dungeon and JUNG when you need more detail.
Yes, I included PASS as the first. He shows some very simple explanations of how one and two semiconductor circuits work.
One needs that basic understanding to move on to using opamps.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 3rd April 2012, 05:55 PM   #14
Balanced headphones, that sounds expensive.
The HeadWize link contains the information you are looking for. Scroll down to the section titled 'Configuring Opams for Voltage Gain' and read the entire section.
Read Andrew's recommended reading before you start the class A amp.
Virtual breadboard of a mono CMOY. Have a few questionsHide this!Advertise here!
Using 2 MC34063 for CMOY virtual ground KungFuPanda Chip Amps 4 21st February 2012 07:44 PM
Cmoy Virtual Ground Setup jtavrisov Headphone Systems 4 9th August 2011 07:00 PM
Audio Newbie Questions on Virtual Surround vonzevon Everything Else 3 21st April 2007 06:00 AM
6L6 mono amp questions rickl Tubes / Valves 27 10th November 2005 03:57 AM
Dual mono questions revell Chip Amps 0 27th August 2004 03:41 PM
Copyright ©1999-2017 diyAudio
