loud hummmmmmmmmm
loud hummmmmmmmmm
Old 1st October 2003, 01:09 PM   #1
moonshow is offline moonshow
Default loud hummmmmmmmmm
hi
its my first time to build a gainclone, i have wired everything up and plugged the amp into a 220 volts socket. all i hear is a loud humm and a faint sound of the music. im a little confused with regards to the diagram.
where do you put the pot?is it between the 4.7 ufd 35 volts cap. and the phono input?cause thats what i did.
are my speaker busted already?
instead of the 56k filter, you can put the pot right? the pot that i have has 3 solder leads, how do you wire them up?
i seem to be lacking some parts in my gainclone.
i have wired up the ff.
4.7 uf 35v cap=1
1000 uf 50v cap=2
220k resistor, 1/4 wat=1
10k resistor 1/4 watt=
thanks for your help.
Old 1st October 2003, 02:12 PM   #2
miguel2 is offline miguel2  Portugal
DONT connect your speakers now! Use first some crap speaker you dont mind to loose.
Measure offset of both channels. Starwire the ground wires. Try it without the pot: input cap (4.7), 10k resistor to -input. +input to ground. 220k on feedback. 1000uF caps on the rails. And youre done!
Miguel
Old 1st October 2003, 03:37 PM   #3
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
Default Re: loud hummmmmmmmmm
Originally posted by moonshow
hi
4.7 uf 35v cap=1
1000 uf 50v cap=2
Miguel
yes, use a rubbish test speaker.
sorry about the bad quality diagram, i hope you get the idea though...
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
loud hummmmmmmmmmHide this!Advertise here!
For those that like it loud RacerXtreme Multi-Way 25 12th September 2007 04:02 AM
How loud can you go? paulspencer Multi-Way 7 28th June 2007 04:12 AM
T-amp, too loud, too soon Mr.Mekulic Class D 16 27th October 2006 04:40 PM
BIG LOUD 3 way? xstephanx Multi-Way 17 4th July 2006 09:43 PM
how loud do i need to go badger Multi-Way 6 8th January 2002 07:24 PM
Copyright ©1999-2017 diyAudio
