RIAA preamplifier for turnable Ziphona MA 224
Old 29th March 2012, 06:37 AM   #1
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
Lightbulb RIAA preamplifier for turnable Ziphona MA 224
Hi people!
What's the best RIAA preamplifier for turntable Ziphona MA 224?
Thank you!
Old 29th March 2012, 06:48 AM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Does it even need a RIAA? Is the cart not ceramic?
Old 29th March 2012, 08:29 AM   #3
formula 22's Avatar
Red face Ziphona MA 224 Riaa premp?!
Earpiece is a type of MM, at least I think so?
It should be checked in dataschet this turntable?
Let's move on,....
Old 29th March 2012, 10:04 AM   #4
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Ziphona was the east german turntable maker. I used to service those many years back. There are some east german turntables worth keeping, but the MA-224 is really poor IMHO, most of them actually are. There are only a handfull of belt drive Tables that where international standard and the very last direct drive / linear tracking ones, but only the Top of the range, not the ones with plastic arms.
Check the cartridge, if it is the common east german MM pickup then use any MM Phono pre. If it is the Piezo Pickup then it needs a 1MOHm input impedance and is approximately equalised and line-level already.
The Piezo-Pickups have CS-XX (where XX is some number) written on them, the magnetic systems have MS-XX (where XX is some number) written on them.
Anything else, check the make/model of the cartridge.
EQ is determined by the LP, not cartridge or turntable.
Ciao T
Old 29th March 2012, 12:37 PM   #5
formula 22's Avatar
Wink CS 29
Ciao T
On the speakers says:
RFT
Web nell DDR
CS 29
Old 29th March 2012, 01:31 PM   #6
RFT
Web nell DDR
CS 29
CS-29 is a ceramic cartridge, it was designed for 1MOhm input impedance and no equalisation or amplification. IIRC the output will be around 150mV or so..
This is an extremely low fidelity cartridge. The output will follow the LP Equalisation only very approximatly and have very large deviations from flat.
Back in my day we used to joke "RFT = Reicht Fünf Tage" (lasts 5 days before it breaks).
For the life of me I cannot imagine the path this record player must have taken to end up in El Salvador though.
Ciao T
Old 29th March 2012, 02:15 PM   #7
formula 22's Avatar
Question Riaa pream for CS-29?
Hi ThorstenL !
What RIAA preamplifie for CS-29 to recommend?
I made ​​the RIAA preamp by this schematic, but in the secondary area (from 1 ... 3kHz) is the large distortion?
And this gives the preamplifier gain of about Au=60dB is too high.
thank you and cheers!
Old 29th March 2012, 02:30 PM   #8
No RIAA. No Preamp.
Just 1MOhm input impedance. Basically any high impedance will do. Like OPA2604, connected as buffer, 1MOhm resistor on input to ground.
But the CS-29 has very poor sound quality. Best not bother.
Ciao T
Old 29th March 2012, 03:19 PM   #9
formula 22's Avatar
No RIAA. No Preamp.
Ciao T
Do I create such a buffer for the CS-29.
Old 29th March 2012, 03:36 PM   #10
Yes, but remove the capacitor C1.
If gain is not enough you add some gain for the Op-Amp, but no EQ.
Another option I remembered is given on this page:
Stereo Pickups & Phono Cartridges : 1958 - today – Stereotonabnehmer
This should make the CS29 work with a normal MM Phono Stage, no idea how well, never tried it. Even in East Germany I stictly used Moving Magnet Cartridges! Piezo is very low quality.
Ciao T
RIAA preamplifier for turnable Ziphona MA 224Hide this!Advertise here!
RIAA preamplifier JPS64 Tubes / Valves 0 5th May 2011 06:36 PM
AR Turnable for enjoyment and tweaking smiler Analogue Source 5 30th March 2011 06:13 PM
Crown MA-12000i / MA-5000i / MA-9000i jack2040 Solid State 4 8th March 2011 01:21 PM
LM833 RIAA Phono Preamplifier gmilitano Analogue Source 2 7th March 2005 05:26 AM
Turnable mat and record brush roy1xord Analogue Source 2 29th February 2004 01:04 AM
