| Chip Amps Amplifiers based on integrated circuits |
#11 |
Hi
Here are the photos the piezo-pickups CS-29, and photos turntables Ziphona MA=224. Which schematic is required to exit? Why Mr.ThorstenL turntables Ziphona MA-224 with this we need the RIAA preamplifier than usual amplifier with gain of Av= (8 .. 10)dB and the input impedance of 1Mohm? Thank you and cheers! Last edited by formula 22; 30th March 2012 at 05:24 AM. |
#12 |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
I know 1MOhm input buffer will work, because that is how they where used with the other east German Equipment. Radio's, Amplifiers etc. all had inputs labelled "TA" for ceramic inputs that where 1MOhm, minimum capacitance. The three resistor attenuators I do not know if they work well or not. But as you already have build a MM Riaa Pre, trying them would be easy. If it is still is not good, use the 1M input impedance buffer... Ciao T |
#13 |
Hi
Is this schematics can be used as a preamplifier for Ziphona MA 224? Or they need some changes? ![]() ![]() thank you! |
#14 |
#15 |
Hi all!
![]() I made this schematic saves preamp for piezo pickup CS-29 (Ziphona MA 224) and now everything is OK! ![]() Excellent turntable to an amplifier can be heard now and enjoy music Dire Streits! ![]() ![]() Cheers!
#16 |
#17 |
Hi all!
I want to can this ceramic pickup I create a buffer with mosfet BS170 or similar with the input resistance of 1Mohm that I see with this buffer to turntable sounds? Power supply to be Ucc = 9...12V So please give a proposals circuit (schematic). thank you! Last edited by formula 22; 21st April 2012 at 05:05 AM. |
| RIAA preamplifier | JPS64 | Tubes / Valves | 0 | 5th May 2011 06:36 PM |
| AR Turnable for enjoyment and tweaking | smiler | Analogue Source | 5 | 30th March 2011 06:13 PM |
| Crown MA-12000i / MA-5000i / MA-9000i | jack2040 | Solid State | 4 | 8th March 2011 01:21 PM |
| LM833 RIAA Phono Preamplifier | gmilitano | Analogue Source | 2 | 7th March 2005 05:26 AM |
| Turnable mat and record brush | roy1xord | Analogue Source | 2 | 29th February 2004 01:04 AM |
