Questions about the LM3876T, please help - diyAudio
Old 1st October 2003, 02:17 AM   #1
Paprika is offline Paprika  United States
Default Questions about the LM3876T, please help
I think, I'll be doing 3 of these guys : http://sound.westhost.com/project19.htm ; Left, Right and Sub...
I am going to use this system for a few years as a sound amp for my small entertainment center. Where I can have a audio switch change the input between 5 different sources (Cable Box, DVD, Xbox, etc.). Simple stuff.
- Any problems so far?
From what I understand I am going to need crossovers in each speaker (L, R, Sub) so that each speaker is only making sounds it's suppose to (in layman's terms). I had planned to buy speakers, so can I expect to find that the crossover will be built into the speakers?
so make absolutely sure that the amp is only used in applications where clipping will never occur.
What is this clipping he talks about and how can I prevent it?
Any galleries of homemade audio equipment so I can get some ideals on how to do my chassis? All I know now is that I was planning to use a small fan to circulate air through the system...
If you guys could please help me out with those things I would greatly appreciate it. Thanks!
Old 1st October 2003, 04:04 AM   #2
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
LM3876 has mute, LM3875 no mute, otherwise the specs are pretty much the same, and many here rave of the sound of the LM3875 while talk of the 3876 is almost non existant. I'd say use the LM3875 because it would be just that much simpler. And while you're at it, do a search for "gainclone" the standard circuit people are using to build their gainclones is simmilar to Rods (the ESP pages project) except it is an inverting amplifier (flips the output wave) and this does indeed sound better than the non-inverted circuit (the one you proposed) but also brings other problems into the mix (input impedance).
But since the inverted amp is simpler to build and sounds excellent I'd recomend you give it a try. As for chasis examples, PassDIY.com has a gallery of pass labs clones/inspired projects, and Nuuks site (decibel dungeon I do believe) had a gallery of gainclones.
Old 1st October 2003, 08:09 AM   #3
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
At your service sir!
The Decibel Dungeon Gainclone Gallery
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Do Chip Amps (LM3876T) Require a Lot of Burn-In Time? Steve M Chip Amps 9 31st January 2008 12:12 PM
LM3876T GC first impressions wiredmonkey Chip Amps 1 23rd January 2008 09:55 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
gainclone with a lm3876t? saletel Chip Amps 4 14th January 2003 03:34 AM
Copyright 1999-2017 diyAudio
