I have a LM 3886 lying around - does it work ? - diyAudio
Old 26th March 2012, 06:08 PM   #1
Default I have a LM 3886 lying around - does it work ?
Hi
I have one of these left from a cooked 2 ICs Behringer amp - I suspect it was the other one cooked so I kept this one, I guess 50-50 it may work.
Is there any way I can test this with a meter other than building it into an amp first ?
thank you
Old 27th March 2012, 01:35 PM   #2
Do you need to be sure?
If so then hit it really hard with a 3/4 kilogramme hammer. Now you are sure !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th March 2012, 01:45 PM   #3
Thank you for your kind suggestion, strange as it may seem I need to be sure cause I want to use it. It can go into a cooked bass amp but that involves unwinding the transformer to lower the psu ac output so I would like to know if it works before I start doing that.
Old 1st April 2012, 04:56 PM   #4
Surprised no one has anything to say re this ? Is it in a FAQ or what ?
I built the chip into a 4 resistor amp (muting bypassed) and I get nothing in the ouput, no great current drawn either
Then I measured that pin 3-out to 7-gnd is 33Ohms only - is that how it should be ?
Old 1st April 2012, 06:12 PM   #5
wazzy is offline wazzy  Zimbabwe
try this it's about as simple as it gets and cheap too just for testing, test and see if you get any dc on the output this would indicate shorted output transistor if nothing input a signal and try it on a scrap speaker, hope this helps.
Old 2nd April 2012, 08:45 AM   #6
Well that's exactly what I did - and I got absolutely nothing in the output, it behaves as if it is muted or as if there is nothing inside
lm 3886 larryg Chip Amps 6 1st June 2009 06:38 PM
LM 3886 bridged costy_ro Chip Amps 40 28th April 2006 12:05 PM
LM 3886 Tips... -_nando-_ Chip Amps 39 10th January 2006 06:27 PM
Copyright 1999-2017 diyAudio
