| Chip Amps Amplifiers based on integrated circuits |
#31 |
#32 |
If you navigate your browser on over to Heat Sink USA and select a profile, it says RIGHT AT THE TOP OF THE PAGE the heat transfer per length of heatsink (or per length specified if not 1").
It doesn't get simpler that that. -Charlie |
#33 | |||
I was referencing Marra's post about the chunk of aluminum 10x80x300mm. If I recall correctly, I mentioned that I was tired. Thanks for the correction. Quote:
Although I could see problems with that being dimensionally unstable (warps, etc causing surface contact voids) and so probably more prudent to use properly machined aluminum stock. Quote:
Thanks all, i know SO much more about heatsinking than I did when I started. Really, I mean that. Last edited by hpp3; 28th March 2012 at 08:14 PM. |
#34 | |
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#35 | |
Thank you, Sir. |
#36 |
some commercial products DO use zigzagged sheet metal crimped to a piece of L-angle as a heatsink. It is usually quite inferior to a real aluminium extrusion.
For the chipamps you mention it will probably be adequate, however by the time you have manufactured this yourself (unless you have the tools and materials to hand for little/no cost), you can buy a sensible extrusion already. For your reference, A 2xLM3886 amp I built uses a 160mm wide, 25mm deep, 70mm high non-anodised extrusion I got from eBay, with 25v supplies. It gets warm when driving a 4 ohm load at decent volume, but not excessively so. |
#37 | |
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#38 |
I use rough approximate formua, it works for me. Resistance in Celsius degrees per watt equels 50 divided by square root from area in square centimeters.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#39 |
That sqrt & 50 sounds familiar.
What does ESP say on the subject? |
| how easy to make tube amp? | space2000 | Tubes / Valves | 4 | 28th June 2008 11:24 PM |
| Easy PSU question - help me make this 12v DC power supply better. | owdi | Power Supplies | 8 | 2nd May 2007 04:42 PM |
| Class A heatsinking, or heatsinking in general! | NUTTTR | Solid State | 27 | 22nd January 2005 01:48 PM |
| DIY Turntable Concept (Easy-to-make) | comabereni | Analogue Source | 10 | 10th November 2004 10:30 PM |
