| Chip Amps Amplifiers based on integrated circuits |
I need to build an 8 channel amplifier for my active dipole speaker. I just picked up 8 of these heatsinks, measures 9.25x4.4x0.5" each. Is one of these heatsinks sufficient for a single channel of LM3886 at around 50watts?
Second question is an asthetic one. I had originally thought of placing all 8 channels into 1 chassis, all paralleled in a row. I've got an appropriate chassis cover from an Anthem tube amp, I'd need to put together a front, rear and bottom for it. Or I could build two seperate chassis' and make them look something like the original Pass Aleph amps. What do you guys think would make more sense from a wiring and layout perspective? |
#2 |
Measurement is 4.5" high.
Here's a shot of just a single heatsink. |
#3 |
Did you get that at Princess Auto?
I've used this one for 2 LM3886s at 40w each and it barely gets warm. http://www.bgmicro.com/prodinfo.asp?...t+sink&stype=3 I can't imagine your sink getting too hot with just one IC on it.
#4 |
Banned
transducer your not burning a music cd with your burner are you : O )
woot a apple user :" O ) |
#5 |
Sean: yes, I got them at Princess
Only $69 all in for 8 of them, thought it would be a good deal.Jason, yup, that's an original TiBook on my desk. But I deny all knowledge of burning any music disks Guess I'm good for 8 channels, maybe more Cheers, RonS |
#6 |
Banned
yup i know what it is. used to have one the 400 mhz with 1-gig memory and dvd drive. i called it a hot pad as it got to hot to have on your lap..
i'm selling my 1 gig tower that i have 2003 model 3 months old to get the new 15" aluminum pb : O ) |
#7 |
Yes, mine is the original 400Mhz model. I've uped the ram to 768M, and put in a CD-RW in place of the DVD rom. I need to burn disks for work (photographer).
I had sort of tried to dump it in anticipation of getting a new powerbook, but got no reasonable bites. I'm lusting after a new G5, but am waiting for the second coming. I got burned a bit on a first generation G3 that doesn't properly support more than one HD. Back to audio now Cheers, RonS |
#8 |
Banned
email me ..
jasonleaman @ shaw. ca |
#9 | |||
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#10 |
Banned
yeah lots of time.
| lm 3886 | larryg | Chip Amps | 6 | 1st June 2009 06:38 PM |
| pre amp for 3886 | bostonswoop | Chip Amps | 6 | 19th June 2006 02:58 PM |
| NAD3130 heatsink suitable for gainclone ? | ash_dac | Chip Amps | 1 | 12th June 2006 07:41 PM |
| Impressions of Snubbered BrianGT 3886 vs Reg 3886 | moving_electron | Chip Amps | 1 | 23rd March 2005 06:51 AM |
| Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? | Layberinthius | Tubes / Valves | 0 | 11th March 2004 08:49 PM |
| Page generated in 0.10321 seconds (77.29% PHP - 22.71% MySQL) with 11 queries |
