Audio delay circuit
1 Attachment(s)
Hello,
I was looking for analog delay circuit of 2seconds, which can delay the audio signal (input) by digital or active\passive analog components and have delayed analog output. I have come across one circuit but not able to find the components which is attached to this thread, that may also help you to suggest me any other circuit or method. Regards, Dileep |
What bandwidth do you need? That circuit's for voice as far as I can see, it runs at 64kbits per second.
<edit> Note to mods: I see this was cross-posted to Analog Line too - a better place for it would be Digital Line as its not really possible to do analog delay of 2s and that pdf is a digital solution. |
Yes mainly required for voice application!
Thanks for your interest for help. Deekay Quote:
You could have a look at this chip : http://www.holtek.com.tw/pdf/consumer/8972v100.pdf
Its not going to get you near to 2s - you'd need quite a few (maybe 6) in series as their selection guide says one chip is good for up to 330mS. |
Thanks for your reply!
Yes delay is very less 320msec! Hope someone will come with required circuit. Regards Deekay Quote:
| All times are GMT. The time now is 09:42 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
