Smoothing capacitors for LM3875 power supply
Old 14th March 2012, 12:56 PM   #11
R.I.P.
Originally Posted by Redshift187 View Post
With such a small VA transformer, there wouldn't be a lot of point going for too high a value, but I would go for at least 4700uF per rail.
I think the opposite.
When using a transformer that is a bit lower VA rating than normally recommended, I add extra smoothing capacitance to "beef up" the supply.
My intention here is to keep supplying transients and operating current from the smoothing, until the too small transformer has time to charge up the capacitors some time later when demand has dropped a bit.
The effect is that a low impedance of the smoothing is paralleled by the high impedance of the transformer.
Changing one can to some extent be compensated by moving the other in the opposite direction.
regards Andrew T.
Old 14th March 2012, 02:57 PM   #12
maurycy is offline maurycy  United States
I can get the 10,000uF and put one per rail.
Now from the scientific point of view, I have two Nichicon caps that I am looking at:
1. VZ series with ripple current of 2850mA, 105degC
2. FW series with ripple current of 4000mA, 85degC
Does the ripple current make a difference here? All other basic specs are the same though the FW series has longer load life which I assume is because of the lower max operating temperature.
Thanks.
Old 14th March 2012, 03:01 PM   #13
R.I.P.
I think the longer life is down to the lower losses inside the FW. Those lower losses are reflected in the specification value of Ripple capacity.
regards Andrew T.
Old 14th March 2012, 03:22 PM   #14
Thanks for the explanation. I have also read that the life span is calculated based on the maximum operating temperature. That 20degC may play a difference here as well.
Old 15th March 2012, 03:05 AM   #15
Redshift187 is offline Redshift187  Canada
Life span is increased with higher max operating temperature. The farther you run a cap from the max temp, the longer it lasts.
Tyler
Smoothing capacitors for LM3875 power supplyHide this!Advertise here!
Fotios need help with power supply smoothing capacitors. fotios Solid State 13 15th August 2007 02:08 AM
Problem building a power supply, no output after smoothing caps? markiemrboo Parts 11 15th January 2007 05:10 PM
LM3875 power supply questions... nycavsr2000 Chip Amps 3 11th October 2006 05:42 PM
4x Elna Silmic 22000uF 56v Smoothing Capacitors (very rare) Kevinbd Swap Meet 13 23rd March 2006 11:57 AM
HV smoothing capacitors DeXXSter Tubes / Valves 8 11th December 2001 10:10 PM
