| Chip Amps Amplifiers based on integrated circuits |
Hi Guys,
Can you guys tell me please how to calculte the SPL of an speaker while having the acoustical/electrical power of the connected amplifier? For instance is it easy to have an approach/relationship of the ouput SPL by knowing the power of an amplifier, for instance we know the power of the LM3886 is 68W at 4ohms when connected to a supply of say -+28V, So can we make a guess or calculte the ouput SPL? Thanks a lot |
#2 |
Your amplifier outputs around 70W at its clipping point so maximum music programme into loudspeakers will be around 10 watts average with music programme that has low dynamic range. (For high quality uncompressed programme the average power can be much lower.) With a pair of 4 ohm speakers you look at its "efficiency" dB/W/1m. Say that is a typical 87dB/W/1m (90dB/2.83V/1m for a 4ohm speaker.) 10W is +10dB, and you have two channels / speakers + 6dB, but you don't listen at 1m, room size becomes important. In a typical room about 97dB maximum average SPL is about right. Double the room size take away 3dB, double amplifier power add 3dB. If the speakers are 84dB/W/1m take away 3dB. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 9th March 2012 at 12:30 PM. |
#3 |
If you go back and read the HiFi News reviews of amplifiers you will see thay always quoted maximum power in Watts.
But then showed a table of max Power at various frequencies & test loads in dBW A 100W amp would show as +20dBW. But actual figures in the table could be +21.1dBW @ 100Hz, +22.0dBW @ 1kHz and +21.7dBW @ 10kHz. all into 8r0. Then they would show the dBW values into 4r0. and 2r0 if appropriate. These latter figures really did show up amplifiers that could not deliver adequate current Simply add the yydBW figure to the sensitivity value of the speaker which is usually specified as xxdB/2.83V @ 1m Last edited by AndrewT; 9th March 2012 at 12:36 PM. |
#4 |
A crude way is in a scientific calc do '10log(base10)(power into speaker)' then add that figure to the efficiency of the driver/speaker. This obviously doesnt take excursion room size or anything like that into account.
I thought about it once, but then thought again. |
#5 |
It is worth noting that speaker sensitivity is given at 1 m in anechoic surroundings. Practical listening rooms usually aren't terribly anechoic - as a rule of thumb, 1 m anechoic corresponds to the typical 2..3 m listening distances there, which is quite handy.
When specifying minimum recommended amplifier power, loudspeaker manufacturers tend to shoot for about 100 dB SPL. That's a fairly sensible value. Sadly, sensitivity specs on loudspeakers as given by manufacturers are not always reliable - sometimes it seems they are just pulling them out of thin air. If you see something with a 7" / 17 cm woofer that claims 91 dB / 1 W / 1 m, better look for some actual measurements. (Even for a 4 ohm affair and at 2.83 Vrms, this seems quite high.) |
| SPL | joco000 | Construction Tips | 2 | 2nd February 2012 07:54 PM |
| SPL@2.83V or SPL@1W ? what is right? | Astro Power | Subwoofers | 6 | 29th December 2005 10:58 AM |
| Power, SPL v Vb | Mos Fetish | Multi-Way | 7 | 1st December 2003 03:45 AM |
| max spl(and power handling) at diff. frequencies | Keith D | Multi-Way | 11 | 3rd August 2003 06:11 AM |
