First attempt to build a Power amp! - Page 2 - diyAudio
Old 28th September 2003, 09:43 AM   #11
li_gangyi's Avatar
I would dare to say that probably your PSU is not working well...try it without he switchmode PSU...use a "standard" PSU to power it up and test...before you proceed to the SMPSU...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 28th September 2003, 09:52 AM   #12
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
How? I don't own a 220v=>40-0-40 transformer and i don't think that i can find a commercial one...
Anyway i've tested the PSU and a it produce 2.2A from 1.4A as input. Infact i use a 220=>+14V@1.5A to feed the SMPS(my old Creative supply ).
So u think my problem is the SMPS????
Old 28th September 2003, 09:56 AM   #13
li_gangyi's Avatar
You really should heatsink the Darlingtons...and try another PSU...seems to be the SMPSU...under a volt...under load is not a good thing...
Old 28th September 2003, 10:00 AM   #14
MaXiZ's Avatar
Absolutely but for the moment that was only for a test...
BUt this should be mean that thecircuit take all the curren/voltage or not?
Old 28th September 2003, 10:19 AM   #15
li_gangyi's Avatar
Even if they take all the current..the voltage should not "drop" meaning the SMPSU might not be giving enough power to the amp...OR the amp is having a really heavy short which is causing such a BIG current draw...but since you told me it's less than 1 amp current drawn...I'm not really sure the figures tally...so might be your SMPSU...
Old 28th September 2003, 11:19 AM   #16
MaXiZ's Avatar
I don't understand so clearly.. u say that the voltage is too low for th amp... my SMPS don't produce enough current?
Old 28th September 2003, 11:49 AM   #17
li_gangyi's Avatar
Yup...your SMPSU is not having enough current...but the voltage is probably enough...only because the amp draws a big current does the voltage dip...
Old 28th September 2003, 12:17 PM   #18
MaXiZ's Avatar
So my problem maybe only the current...
I've made a check...
At the input of primary 9A.. output of each secondary...0.5A!!! AAAAAAAAAAAHHHHHHHHHHH!!!!
What maybe? Wrong frequency? Wrong winding of transformer?
Old 28th September 2003, 12:26 PM   #19
li_gangyi's Avatar
I'm not so sure..I dun really work with SMPSU...so I can't give you many tips...
Old 28th September 2003, 01:39 PM   #20
MaXiZ's Avatar
COuld u explain this to me?
Best DIY power-amp/kit to build? WE91 Solid State 45 24th January 2015 09:10 PM
Want to build hi - power amp Jack6428 Tubes / Valves 5 26th September 2005 09:51 PM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Copyright 1999-2017 diyAudio
