| Chip Amps Amplifiers based on integrated circuits |
#22 |
What can i say, you can never have "enough" amps
![]() These should compliment your existing setup very well. Where can i get those 10000uF Samsung capacitors in Chennai? |
#25 |
It looks like you have taken on board very little of the advice that is offered.
#26 |
How about this design:
[img=http://s8.postimage.org/ovpg3qyr5/lm33.jpg] |
#27 |
The entire right side needs a ground plane on the side oipposite the signal traces, or, at the very least, fill everything with a "ground pour" of copper so that there is absolutlely-minimal space between the signal and signal ground conductors, everywhere. Otherwise you will have a good antenna for the hum from the AC Mains and transformer secondary wires, which also need to be tightly twisted, everywhere, so they don't make good transmitting antennas. (See Faraday's Law.)
Also, your small decoupling/bypass capacitors are too far from the power pins. And the +28V one is MUCH too far away. I would also just fill the entire area between +28 and -28 with ground copper. If you have a 2-sided board, you are definitely not taking advantage of it. ALWAYS use a ground plane, covering one whole side, if you are able to have a 2-sided board. In this case, you will keep the signal and power grounds separate, of course. |
#28 | |
I've never used a ground plane or even a ground ring for an LM3886 amplifier, I never needed it. I even built one "in the air" without a PCB. No hum. The pcb design shown is just fine. Perhaps the 100n decoupling caps could have been closer to the power pins, but I don't think they're "much too far". Also I would have put a 10ohm resistor between the power and signal grounds. |
#29 |
You don't need a 2layer PCB.
You don't need a Ground Plane. You don't need any pour fill. Get the traces for every FLOW & RETURN pair very close together. That reduces the loop area. That is by far the most important parameter: LOW LOOP AREA. |
#30 | |
1) 2-sided pcb with ground plane opposite signal traces 2) 1-sided with copper pour to fill ground around signal traces and pads and under signal components 3) 1-sided with existing signal and signal ground traces moved closer together. |
| lm3886 single sided pcb | ryan750 | Chip Amps | 37 | 27th May 2013 04:15 AM |
| Dual layer PCB with second layer being only ground | Th3 uN1Qu3 | Class D | 16 | 6th February 2011 10:32 PM |
| Single sided non inverting LM3886 PCB | tla-Audio | Chip Amps | 35 | 1st April 2009 07:16 AM |
