Old 12th March 2012, 04:14 PM   #11
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Dear kulddepJee,...nice to hear that u still paly with Chip amps..btw whci program do u use
SivanandBalan
Old 12th March 2012, 05:10 PM   #12
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh
Hello sivan ji... thanks for the comments ... i am using eagle now...
eagle pcb software. its quite easy to use.
My Blog
Old 30th March 2012, 09:18 AM   #13
neeraj is offline neeraj  India
Good job Bro!!
Neeraj
Old 30th March 2012, 10:48 AM   #14
hoping to receive first supply of PCBs today
My Blog
Old 30th March 2012, 10:50 AM   #15
By the way could you please specify Pitch of Power Capacitor. Snap in type will work ??
Please Post snap of finished PCB .
Neeraj
Old 30th March 2012, 11:02 AM   #16
pitch is 5 mm to 7.5 mm, both can come. i'll post pic as soon it comes.
My Blog
Old 30th March 2012, 10:50 PM   #17
jaycee is offline jaycee  United Kingdom
Do you want the mute function? If not, just wire the mute pin to -V via 22Kohms. No need for the extra parts then
Old 31st March 2012, 06:45 AM   #18
@jaycee. Ya, thats why i provided jumpers, simply put a jumper there or connect a push-on-switch if you want a seperate mute switch
My Blog
Old 31st March 2012, 07:12 AM   #19
Got the PCBs Yippee
received 18 PCBs today...
(only issue i found was the smaller holes for the IC mounting, i have to enlarge it manually only)
any1 interested to buy, available for 150 INR per piece
My Blog
Old 14th April 2012, 11:58 AM   #20
Finished amplifier modules...
One PCB with basic components and second PCB with all extra components (Output inductor and resister, 220pF, 47pF and 22K and with cable provision for mute switch).
One small issue in PCB track was one pad of 220pF was not connected. And another thing was i forgot to apply thermals
Last image shows simple Power supply using 10 Amp rectifier module and 10,000uF caps.
My Blog
lm3886 single sided pcb ryan750 Chip Amps 35 Yesterday 12:42 PM
Dual layer PCB with second layer being only ground Th3 uN1Qu3 Class D 16 6th February 2011 10:32 PM
Single sided non inverting LM3886 PCB tla-Audio Chip Amps 35 1st April 2009 07:16 AM
Copyright ©1999-2013 diyAudio
