First build, Dual-Mono LM3875
Old 6th March 2012, 05:23 PM   #1
AlexQS is offline AlexQS  United States
Default First build, Dual-Mono LM3875
It seems that things are starting to come together here. Transformers arriving on Thursday hopefully. I chose two 330VA 25v + 25v
I practiced soldering with a radio-shack kit. After a little practice things were begining to look good.
Then on the LM3875, my first couple of joints didn't turn out so well. They just look a little gritty and dull. It is difficult to photograph shiny things, but the others look mirror-chrome-like shiny, so that's good
I tried to reheat/reflow the two that look dull, it seemed to make it worse, so I stopped messing with it. They look a little better now that I have scrubbed off the rosin stuff, not too gritty anymore, but not as shiny as the rest. Should I remove the solder with a wick, and then start over?
There is one place that I have created a solder bridge, but I think that that part of Rf and R3 on the board are connected anyway, right?
Board around pin 11 on chip started to melt, but I don't think too bad. I don't think there is much I can do about it now.
So here is a macro 1:2 photo. Be nice (and honest), it's a close up, and my first try after practicing with only a couple dozen or so LED's and resistors from Radio Shack.
p.s. I highly reccomend this little magnifying glass thing. My eyes are getting old, and this thing was only $4. Not highest quality, the arms are hard to lock into a position, but I only use the glass part anyway.
More to follow soon next week or two. I think you'll like my concept and design for chassis!
AlexQS
Old 6th March 2012, 05:40 PM   #2
No 4 is offline No 4  United States
I also practiced with radioshack parts. Great idea!
What kind of solder are you using? Any pics of the enclosure?
Old 6th March 2012, 05:51 PM   #3
No pics of enclosure yet.
I'm using Kester rosin-core SN63PB37 0.020" It is much easier to work with then the other solder I have, I think because of the small guage, and because it contains led.
I also have some Cardas Tri Eutetic, but it's 0.031" led free. It is just too big to use on the pcb's, but I'll probably use it for the cross-overs in the speakers that I'm building.
I have a small package of 0.050" silver solder that I got for cheap from a hardware store. Great for tinning a new solder needle.
AlexQS
Old 6th March 2012, 06:21 PM   #4
GloBug is offline GloBug  Canada
Banned
AlexQS
Yes they appear to be connected on the board. (And from memory)
The burn around pin 11 looks like it might be just burnt rosin flux, which is a little more stubborn to clean. That's what it "looks" like from here.
The rest look good, I would visually recheck the rest and not subject the chip to anymore heat unless needed.
Old 6th March 2012, 10:47 PM   #5
ChristianThomas is offline ChristianThomas  United Kingdom
Location: On a hill, in a wooden shack, next to the woods, in Somerset.
Wow, you really have chosen overkill with those transformers. That's fine and won't do any harm, but you are going to get about 44V on each rail from them. That is at, if not beyond, the limit of what a 3875 can take. Up on the limit is not a good place to be anyway, but it's worse in your case because it's hardly going to fall by much under load.
I would suggest that you have to lose some voltage somewhere. Two easy ways, both of which are nominal improvements, are to have two bridges - one for each half of the supply and possibly split the reservoir caps with a resistor. Otherwise I would suggest a regulated supply or at least a cap multiplier that can knock off a few volts and give you the proper voltage. The voltage you need will depend on the load of your loudspeakers but I would suspect that 37V is probably the sort of region you would need to be looking at for a general design with a 3875.
I doubt that the 3875 will blow on 88V unloaded (its absolute limit is supposed to be 84V) but you will need a proper sized heatsink to keep it out of trouble and stop its protection kicking in.
The other thing you could do is to "unwind" a few turns on the transformer. This is not to actually unwind them, but to wind reverse turns on each side so you get a lower voltage. To gauge how many turns just wind 20 turns around it, anywhere, and read off the voltage you get. Then, in the right direction, take a tap off the output, and backwind the unneeded turns.
Hope this helps and hasn't frightened you too much.
Christian Thomas
Old 6th March 2012, 11:01 PM   #6
Banned
25v times 1.4 = 35v, not 44
He's right on the money.
Old 6th March 2012, 11:32 PM   #7
@ SoIL4X4 - This may give you an idea of the chassis plan I have in mind. I want something very solid. When I was a kid we had an integrated with a chassis made of ceramic. I guess I was "sold" on the idea of having something that doesn't vibrate much. I have poured concreet sidewalks around my home, and thought it would be within my capabilaties to make a "shelf" to mount the components to. Perhaps I would use a concreet "Paver Tile", or maybe a thick "Marble Tile" (depending on cost). Below is a photo of my stereo stand. Imagine two (1 left and 1 right) "End Tables" or "Night Stands". I will have two "Shelves" between 4 wooden legs of each table. -It will match the stereo stand and be the same height, with a glass top. One shelf will have the transformer and rectifier board. I will make a nice embelicle cord (I have a nice sheath + heatshrink tube, etc) to connect to the amplifier pcb on the other shelf. -Might sound silly, but I think it will match my furniture, and I'll finally have a place to set the remote controll, LOL.
@ Christian -I was hoping to be right around 37volts per rail, I read somewhere that is ideal. I don't know how to calculate it, but I think I should be close to that. I know many people go for a 300VA 22v + 22v. I am hoping to get a little more detail depth in the sound stage by being at a higher voltage. Mind you that I would never connect anything less than an 8 Ohm speaker.
@ Globug. Thanks for checking out my pics. I thought that Rf & R3 were connected anyway. It makes my consciouse feel at ease when I double check with someone. -I picked up some hardware, nuts, bolts, a tap/die thing, and heatsinks today. They are 3" x 6" x .75" aluminum, I think it should be sufficient, but I will monitor their temp. Surprisingly inexpensive. I am going to polish them up real nice, then take them to a machine shop, and have them "Rabbet" or make a step/ledge on each side, so that the ends are thin enough that I can drill hole for RCA on one end, and Speaker binding post on the opposite. My stand-offs are 1" tall, so I'll have room to put a fat wire from the underside of the board at OG, and connect the other end to chassis. Then I'll solder wires to the center of that fat wire to get PG+ & PG-& Speaker Ground stared to the same point.
Old 6th March 2012, 11:35 PM   #8
Thanks. It seems I am learning more and more how to calculate things.
AlexQS
Old 10th March 2012, 10:33 AM   #9
Apologies. I am absolutely wrong. I have two 300VA transformers here and thought they were both the same voltage (at 25V) and the supply I built was giving me +/- 44V. In fact that one is a 30V transformer (which I feel sure I never ordered).
Since one can never quite predict how these things turn out, forward V drops and losses etc. so never quite x root 2, I didn't bother to even do the mental arithmetic and just posted from experience.
So you will be fine. But get yourself a decent soldering iron. I use a Solomon ceramic station which is about £40 but they come under all sorts or names and one without a station can be had for about $12. Makes all the difference.
Old 10th March 2012, 11:34 AM   #10
Originally Posted by ChristianThomas View Post
............Since one can never quite predict how these things turn out, forward V drops and losses etc. so never quite x root 2,.........
if you model it correctly you can predict fairly closely.
That's the basis of software simulators. There is nothing wrong with pencil, paper and mental arithmetic.
regards Andrew T.
First build, Dual-Mono LM3875Hide this!Advertise here!
Grounding layout - Dual mono Bridged LM3875 GAH Audio Sector 1 15th September 2009 04:06 AM
AudioSector LM3875 dual mono classic kit. gychang Swap Meet 2 2nd August 2008 01:28 PM
LM3875 dual mono (Carlosfm/BrianGT) Kooka Chip Amps 2 30th November 2006 07:43 AM
LM3875 Dual mono amp Whitebread Chip Amps 5 26th June 2006 07:16 AM
LM3875 dual mono kit - a few questions. quickshift Chip Amps 17 23rd August 2005 12:43 PM
Copyright ©1999-2017 diyAudio
