Old 3rd March 2012, 09:29 AM   #51
Al600 is offline Al600  Australia
Just looking at the kit manual. The transformer has 1 primary coil and 2 secondarys both providing 25V and 6A. Should I be using both of the secondary coils or just the one. I'm measuring 25V between the 2 outer pins of the power supply input.
Old 3rd March 2012, 09:31 AM   #52
Here's the link to my transformer. Does it have a centre tab because I can only make out 2 seperate secondary coils.
Altronics - Your One Stop Audio Visual & Electronics Supplier
Old 3rd March 2012, 09:36 AM   #53
Have you bought a 230:25-0-25Vac transformer?
or
did you buy a 230:0-25, 0-25Vac transformer?
edit,
the altronics eventually downloaded.
You have bought a 240:0-25, 0-25Vac transformer.
This is a dual secondary transformer.
Old 3rd March 2012, 09:38 AM   #54
I'm honestly not sure. Can you tell from the link I posted? Should I be connecting the 2 secondary coils in series to make 50V or just use one 25V coil?
Old 3rd March 2012, 09:39 AM   #55
lanchile's Avatar
use one secondary! White/orange or red/black. also check that bridge rectifier (position)
Old 3rd March 2012, 09:41 AM   #56
Pixo is offline Pixo  India
looking at the toroid, it's got two secondaries - red & black is one secondary, while white & orange is the other.
Old 3rd March 2012, 09:41 AM   #57
lanchile's Avatar
or
edit,
Andrew, I do not think this X has a CT!
Old 3rd March 2012, 09:42 AM   #58
Ok. So I'm using one secondary and the rectifier is correct. From the toroidal schematic you posted earlier perhaps I need to use both of the secondary coils to power the rectifier?
Old 3rd March 2012, 09:44 AM   #59
lanchile's Avatar
Nope! you just need one secondary for this amp, but you will need the center tap.
Old 3rd March 2012, 09:45 AM   #60
He has bought a Dual Secondary transformer.
If the instructions only specify a Centre Tapped transformer then he must convert the Dual Secondary to Centre Capped.
Should I order the funeral director now, or wait till he stops posting?
Bridged LM4780 kit: 5 Ohms (Min) at 300Hz = smoke? Plammox Audio Sector 5 10th December 2009 03:44 PM
Teac AG-v8050 home receiver turns off after it turns on eroc1313 Chip Amps 1 20th November 2009 03:18 AM
Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! autolink Car Audio 4 15th March 2009 02:12 AM
Chip Amp LM3886 stereo kit - built & ready to go cdoggy81 Swap Meet 8 24th February 2009 08:26 PM
Looking for amp kit that runs on 12V (car battery) maurycy Chip Amps 5 2nd October 2008 08:29 PM
Copyright ©1999-2013 diyAudio
