50W Stereo Kit amp runs for 1 min, clips then turns off. - Page 2 - diyAudio
Old 3rd March 2012, 06:45 AM   #11
Al600 is offline Al600  Australia
I've fixed the capacictor and all was well for 2 minutes but then the same problem happended. I was so sure that was it. Any more ideas?
Old 3rd March 2012, 06:53 AM   #12
lanchile's Avatar
ok. now let's do this:
Remove power to the right channel and turn it on (one channel only)
that way you can trace the channel that is causing the problem.
Old 3rd March 2012, 06:56 AM   #13
Nrik is offline Nrik  Denmark
The wrongly polarized electrolytic is probably not reason for the failure - althoug it should still be fixed.
From the description it sound more like the amp going into oscillations and then goes into protect mode.
To prevent that, you might want to parallel the 22k feedback resistor with a 50pF capacitor maybe in series with another 22k resistor.
Check out testcircuit 2 on page 5:
http://www.ti.com/lit/ds/symlink/lm3886.pdf
You can solder this to the underside of the PCB on the two leads on the 22kohm resistor.
edit: I would just use the 50pF or 47pF capacitor directly parallel over the 22k feedback resistor
Henrik
Old 3rd March 2012, 06:56 AM   #14
lanchile's Avatar
"0 volt from power supply" should go to "speaker ground" right channel
I do not see ground on the right channel!!!
Old 3rd March 2012, 07:09 AM   #15
lanchile's Avatar
Al600! did you put the GROUND WIRE to the right channel already?
Old 3rd March 2012, 07:12 AM   #16
Just tested it then. Same problem I'm afraid.
Old 3rd March 2012, 07:16 AM   #17
just another
wintermute's Avatar
Al6000 could you measure the dc resistance of the speakers you are driving? with 35V rails you should really not be running less than 8 ohm speakers.
for a nominally 8 ohm speaker you may get a reading of perhaps 6 ohms across the speaker terminals.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 3rd March 2012, 07:20 AM   #18
Looks to be 7.7ohms.
Old 3rd March 2012, 07:22 AM   #19
lanchile's Avatar
I saw the connections No ground from "0 v" to modules.
Old 3rd March 2012, 07:24 AM   #20
So I added another cable from speaker ground to 0V. The problem has persisted.
Bridged LM4780 kit: 5 Ohms (Min) at 300Hz = smoke? Plammox Audio Sector 5 10th December 2009 03:44 PM
Teac AG-v8050 home receiver turns off after it turns on eroc1313 Chip Amps 1 20th November 2009 03:18 AM
Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! autolink Car Audio 4 15th March 2009 02:12 AM
Chip Amp LM3886 stereo kit - built & ready to go cdoggy81 Swap Meet 8 24th February 2009 08:26 PM
Looking for amp kit that runs on 12V (car battery) maurycy Chip Amps 5 2nd October 2008 08:29 PM
Copyright 1999-2017 diyAudio
