Old 24th May 2012, 02:59 PM   #381
Hi Andrew:
I'm trying your formula, with C4, C5, R5, R6 and R4 as locations in the XY PCB, I'm using 2.2uF as reference value for C5:
C4 >= C5 * Sqrt(2) * [R5+R6] / R4
C4>= 2.2uF x 1.48323969 x [23000]/680=110.37
Now, when using a reference value of 4.7uF for C5:
C4>= 4.7 x 2.16794833 x [23000]/680=344.64
And using 1uF:
C4>=1.0 x 1.0 x [23000]/680= 33.82
According to this, if one is using 22K Ohm for R5, 1K Ohm for R6, 680 Ohm for R4, then C4 should be 100uF if using a 2.2uF in C5, 330uF if using a 4.7uF in C5 and 33uF if using 1uF in C5. Is this correct?. If that is the case, then I should use the 100uF in C4 instead of the 220uF you recommended.
Old 24th May 2012, 03:07 PM   #382
bcmbob is offline bcmbob  United States
Aguilabrava,
I have bought and sold several items through the use of local purchase and shipping internationally via simple mail like USPS. I one case the total service and shipping totaled close to $70 for $8 of parts. The package shipped to Italy for about $4.50.
So look for a friendly European DIYer
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 24th May 2012, 04:11 PM   #383
Originally Posted by Aguilabrava View Post
Hi Andrew:
And using 1uF:
are your fingers faulty or is it the calculator/slide rule that is faulty?
sqrt(2) ~ 1.414
=105uF use, 120uF or 150uF
4.7*1.414*23000/680=220uF, use 220uF or 330uF
1uF*1.414*23000/680 = 48uF, use 47uF or 100uF.
But all these DC blocking caps result in different bass response.
First has 23k & 2.2uF, second has 23k & 4.7uF, third has 23k & 1uF.
I couldn't compare these different options because each have a different filtering frequency.
BTW,
it's not my formula. I pinched from others before me, I just keep repeating the advice because I found it worked. It removed the sound effect from the NFB cap. Whereas using a too small NFB cap and increasing the input cap to restore the frequency response to where you want it, does make the sound output more susceptible to what type of capacitor is used in the NFB. Make it big enough and you can't hear any distortion due to that capacitor.
Old 24th May 2012, 07:51 PM   #384
I'm sorry, Andrew, it wasn't my faulty fingers nor my faulty calculator, it was my faulty brain, I made a mistake calculating square root of C5, instead of square root of 2, which is 1.414.
Thanks for the correction.
Old 26th May 2012, 04:00 PM   #385
Originally Posted by Pemo View Post
Why these three designers have grounds connected?
They have to be connected somewhere and those designers chose to do it on the board. You will have to ask them personally why they chose that location. The most likely reason is that it was the easiest solution.
Why they sound so good?
How good do they sound?
Is this grounding issue just for safety or also to improve sound?
The connection to PE is for safety.
The connection from line level ground to output and power ground can have an impact on the sound quality. If the ground layout is bad, you get hum from an unregulated supply or cheeping noises if you use an SMPS.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 26th May 2012, 08:16 PM   #386
Hey, Pacificblue:
I'm happy you are finally back...!
What Pemo is referring to is that the guys here, including himself, that have not separated the input signal ground from the power ground cutting the bridges in the back of the PCB don't have any hum at all, their amps are totally silent.
From your answer, I understand that this is just a safety related issue, so leaving those grounds together would reduce the possibility of getting hum, but would make the amp "not as safe"???
Old 26th May 2012, 11:03 PM   #387
Agui,
read what he posted.
PE is the Safety connection.
The Signal Ground to Main Audio Ground is an audio connection.
Old 27th May 2012, 06:29 AM   #388
Me, too. One of my colleagues became ill and I had to take over his duties, so I am quite busy now and don't have much time left to spend with the Forum. The poor guy will probably be down for several months to go and there is no replacement in sight.
It depends on the overall layout whether you need to cut or not. If you have a central star-ground in a multi-channel amp, you may get hum, and then you will be obliged to cut those traces. You may as well be lucky, have a central star-ground and get no hum. Since there are infinite possibilities to lay your amp out, you just have to test it to find out. Some people skip the test and cut the traces just to be on the safe side.
Andrew answered this already.
Let me add that you are obliged to connect the audio ground to PE as soon as the voltage at the speaker terminals can become greater than or equal to 25 VAC or 60 VDC. The only way around this is to create a double-insulated connection from the amp to the speaker, e.g. by means of Speakon connectors on both sides of the speaker cable.
Below those voltages you are not obliged to connect PE to ground, but it is good to do it nevertheless. That way you get used to it and are less likely to forget it when the connection is necessary.
Old 18th June 2012, 01:29 AM   #389
Friends, I have read the entire article regarding the amplifier "Aguilabrava". From what I've seen is a hipanoparlante like me. I congratulate you on the improvements made to the XY LM3886.
I have bought the same kit on ebay and I have replaced the electronics of these amplifiers poer Technics, Aiwa transformer with toriodal of 30 0 30 c and Rod Elliott preamps and phono line. tuner circuit is a Philips PM-FM. tuner.
Result: sound spectacular (with B & W DM602). show a photo. Greetings Jose.
Old 21st June 2012, 12:51 AM   #390
Thanks Agui for your post. It help me to figure out my schematic for my XY pcb with LM3876.
It's a little bit different from you but it's also a three amp desing for active xover.
Hi, New member just bought k272a kit from Oatley Jack5 Tubes / Valves 4 22nd February 2011 01:31 PM
Cheap LM3886 PCB I probably shouldn't have bought. crash42 Chip Amps 17 21st September 2010 06:53 PM
Just Bought a Zaph 5.5 kit... first DIY Humboldt_g Multi-Way 7 29th August 2010 02:16 PM
Bought the kit, now I need parts systemerror909 Class D 2 5th December 2006 05:13 PM
Copyright ©1999-2013 diyAudio
