| Chip Amps Amplifiers based on integrated circuits |
#351 | |
#352 |
That amp looks like a discrete design to me and not a LM3886 based one.
The point of life is to build atleast one audio amplifier before you die.
#353 |
#354 | |
Regarding improvements in the separation of the Input Signal GND from Power GND, I can't really elaborate on this topic since ALL the XY's I have done have the GND's separated, but you and Tekko haven't done it, and you both claim to have totally noise free amplifiers... I'm curious now... This would be a question for AndrewT and Pacificblue, they are the ones that suggest doing it, not only on this thread where it is illustrated with pictures and described in great detail, but in many other threads in this website. Perhaps, I should build one without cutting anything to compare with the separated ones... |
#355 |
You are right, I asked him to post those pictures and more details about his amp, I am interested in getting one of those in the near future. I figured that maybe some other people here might be interested in learning more about them too.
#356 | |
#357 |
#358 |
Lanchile:
Would this one be ok?: http://www.antekinc.com/pdf/AS-4222.pdf It is a 22Vac, dual secondaries, 400VA, that I think would produce 62.21Vdc after rectification, is this right?. Or you mean using a 42Vac, dual secondaries, 400VA, that would give 118.77Vdc after rectifiication, like the one below: http://www.antekinc.com/pdf/AN-4442.pdf I get confussed by "per rail", does this mean 60Vdc aprox. when measuring from +V to GND and -V to GND, or by measuring from +V to -V?. The one I'm actually using for the LM3886 is a 28Vac dual, after rectification I get about 80Vdc if I measure from +V to -V, or about 40Vdc if I measure from +V to GND and -V to GND. If this is what "per rail" means, then I guess the correct one would be the 42Vac dual, that will produce a total of 118.77 from +V to -V and 59.38Vdc when measured from +V to GND and -V to GND... Can you tell me where the right answer is?. |
#359 | |
#360 |
These are the panasonic capacitors
ECWF2225JA - PANASONIC - CAPACITOR, 250V, 2.2UF, 5% | element14 India These are the wima, used two over the board and one below to make them fit. http://www.wima.com/EN/mkp10.htm 100pcs WIMA MKP10 0.1uF 250V Audio Polypropylene Capacitors | eBay Here is the schematic of the PCB clone that you posted: I have made 2 XY ones and 7 "nemo" as you call them ones two of which are with upgraded components, nichicon muse, panasonic and wima MKPs. Will compare the latter to my ultimate BOM MyRef Rev E lated. Waiting fot the enclosure. http://chipamp.com/docs/lm3886-manual.pdf Hope this helps. Last edited by avbuilder; 21st May 2012 at 05:40 AM. |
| Hi, New member just bought k272a kit from Oatley | Jack5 | Tubes / Valves | 4 | 22nd February 2011 01:31 PM |
| Cheap LM3886 PCB I probably shouldn't have bought. | crash42 | Chip Amps | 17 | 21st September 2010 06:53 PM |
| Just Bought a Zaph 5.5 kit... first DIY | Humboldt_g | Multi-Way | 7 | 29th August 2010 02:16 PM |
| Bought the kit, now I need parts | systemerror909 | Class D | 2 | 5th December 2006 05:13 PM |
