| Chip Amps Amplifiers based on integrated circuits |
#111 |
Hey, Fabricated, CONGRATULATIONS AND THE BEST OF LUCK for you and your wife!!!! I know how that feels, I have a 9 months old girl myself...!
This little project has been driving me crazy, but I can't deny I am enjoying it to the fullest, and yes, I would have never embarked in anything like this on my own, these guys here have been of great help, and it is very generous on their part to share the way they do, one of the priceless things in life, knowledge. I am still struggling with schematics, I tried to recreate one with my PCB boards and after 5 hours I gave up, but I'll get there... Now I am almost ready to test what I have done, I am going to get all this stuff hooked up on the top of that old desktop computer you see on the pictures I just posted, I just want to hear this thing playing some Jethro Tull, just one input for now, after I do that, I'll get the enclosure and add the input selector board and the rest of the stuff. So far I believe that your thread and mine are the best ones regarding the "LM3886 chip for dummies", specially for those buying the XY boards at eBay, I think that these guys, specially AndrewT, should "copyright" both threads (including his clever Zobel + Thiele implementation for these boards), I'm sure the chinese sellers at eBay will be including a link to these threads in the package for the buyers. |
#112 |
AndrewT and Pacificblue, you guys are the BEST!!! Thank you!!!!
Here is a picture of the "speaker protection board" I have. It only has a connector block with GND and 12V as you can see in the picture. I was expecting AC GND AC and this is very confussing for me, does this mean it has to be powered by DC???? Also, do I just solder the + LEFT and + RIGHT outputs coming from the amp PCB's to the holes in the other end of the board, and then simply attach the speaker output connectors to the board?. I am including pictures of top and bottom. Thank you again...! |
#113 |
So that would be (2 x 28) x 1.4 = 78.4 Vdc. Meaning that when both amp boards are connected in parallel each amp would recieve 78.4 Vdc from positive to negative and 78.4 / 2 = 39.2 Vdc from positive to ground and -39.2 Vdc from negative to ground. Right?
#114 |
Pacificblue:
Thank you for that image regarding the right way to connect the toroidal to the power supply. I am going upstairs right now to fix it, I had connected BLUE with BLUE and GREEN with GREEN together, and a GRD that goes to the mains GRD in the middle, now I see the right way to do it, thanks again. |
#115 |
Ok, for the rest of the dummies out there (I'm pretty sure I'm not the only one) here is the pictures showing the correct way of connecting the two secondaries to one PSU board, thanks to Pacificblue. The screw on the left of the PSU reads AC, the middle GND and the one on the right AC.
Now when I measure the other end of the PSU (DC coming out side), where the terminal connector block shows +V GND -V, when measuring from +V to -V I get a reading of 80 volts, and when reading from any of the V's to GND I get 40 volts. |
#116 |
Pacificblue, my toroidal has an additional wire because it is a "shielded toroidal", that wire is purple in color, what do I do with it?.
#117 |
That is correct, I just measured mine, I get 80 volts from +V to -V, and 40 volts from any of the V's to GND.
#118 |
#119 |
The shield connects to ground.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#120 | |
Now I read that there is something missing in the circuit: "a Zobel network". Is this what you are talking about? What are the values of the cap and resistor that you recommend? (I don't understand this 2r0) Thanks and RGDS Pemo |
| Hi, New member just bought k272a kit from Oatley | Jack5 | Tubes / Valves | 4 | 22nd February 2011 01:31 PM |
| Cheap LM3886 PCB I probably shouldn't have bought. | crash42 | Chip Amps | 17 | 21st September 2010 06:53 PM |
| Just Bought a Zaph 5.5 kit... first DIY | Humboldt_g | Multi-Way | 7 | 29th August 2010 02:16 PM |
| Bought the kit, now I need parts | systemerror909 | Class D | 2 | 5th December 2006 05:13 PM |
