Bought a XY LM3886 Kit.
Old 29th March 2012, 06:02 PM   #101
Aguilabrava is offline Aguilabrava  United States
Default Pictures.
I have included some pictures here. I know the wires in the connector strip don't look nice, but this was made just for testing purposes, the finished amp will have them nicely attached.
Old 29th March 2012, 06:03 PM   #102
Originally Posted by AndrewT View Post
Tell me, do you have one PSU?
How many wire connections is it expecting from the transformer?
Yes, only one PSU for two amp PSBs.
Old 29th March 2012, 06:03 PM   #103
Your second question will be answered when you check these pictures... :-)
Old 29th March 2012, 06:07 PM   #104
pacificblue is offline pacificblue  Germany
Originally Posted by Corpius View Post
Could anybody explain to me why one needs a tranformer with lower secondaries for 4 ohm speakers then with 8 ohm speakers?
Because power = voltage x current. A 4 Ohm speaker needs less voltage but more current to get the same power.
An ideal amp that delivers 60 W into a 4 Ohm speaker will only deliver 30 W into 8 Ohm. On the other hand, if you optimise the amp to deliver 60 W into 8 Ohm and connect a 4 Ohm speaker to it, then the amp will try to deliver 120 W and may switch off due to internal protecion circuits or be damaged in the process.
I`m building the same amp also with the XY lm3886 ebay kit. I have a dual 24V tranformer lying around. Would this be OK for both 4 and 8 ohm speakers or just 8 ohm speakers?
It would be OK for 8 Ohm speakers. With 4 Ohm speakers it would mean pushing it a bit, and it depends on your listening habits, heatsinking and complexity of the speaker load whether it will work in the long run or not.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 29th March 2012, 06:09 PM   #105
Default Finished Boards.
By the way, I just finished the amp boards, I ended up using a Elna Silmic II 47uf 50V in C4, and the Audiophiler MKP 4.7uf 400V in C5.
I soldered the speaker output wire to the bottom part of the copper that comes from pin #3 and includes the Zobel network, I just need to add the Thiele part to that wire, I just don't know how...
Well, here are the pictures, the black stuff in the bottom is liquid electric tape.
Old 29th March 2012, 06:12 PM   #106
Great, Pacificblue!!!! I was waiting for someone to answer that question, I couldn't do it, but I remember you mentioning it before at another thread, that's why I decided to get the 28V transformer, I only care about 8 Ohm speakers...
Thank you.
Old 29th March 2012, 06:30 PM   #107
fabricated is offline fabricated  United States
Keep it up Aguilabrava! you're getting there one step at a time and getting help from the pro's is a huge plus!
I'm still following closely,yet, I'm at a standstill for a little while.... my new baby boy will be here tomorrow. Good luck!
Old 29th March 2012, 06:38 PM   #108
Originally Posted by Aguilabrava View Post
How do I connect the power from the transformer to the speaker protection board?
You can use one of the 15 V windings and add a voltage regulator to it to bring the 21+ VDC you get after rectification down to 12 VDC. It is recommendable to use a resistor in series so that the regulator need not dissipate 9 V times the protection board current.
On the secondaries side I have 4 pairs of wires, blue and green, blue and green are each 28 volts, then brown and brown, orange and orange are the two secondaries that produce 15 volts each.
If you measure 28 V from blue to green, then one blue wire goes to AC, the green one that belongs to it and the other blue wire go to GND and the green that is left over goes to the other AC.
Old 29th March 2012, 06:47 PM   #109
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Thanks. Would it be possible to use a 4 ohm power resistor in series with a 4 ohm speaker to achieve 8 ohm or would this do good to the sound?
Old 29th March 2012, 06:49 PM   #110
Corpius's Avatar
My speakers have a 8 ohm resistance, so no problem here. Just curious.
Bought a XY LM3886 Kit.Hide this!Advertise here!
Hi, New member just bought k272a kit from Oatley Jack5 Tubes / Valves 4 22nd February 2011 01:31 PM
Cheap LM3886 PCB I probably shouldn't have bought. crash42 Chip Amps 17 21st September 2010 06:53 PM
Just Bought a Zaph 5.5 kit... first DIY Humboldt_g Multi-Way 7 29th August 2010 02:16 PM
Bought the kit, now I need parts systemerror909 Class D 2 5th December 2006 05:13 PM
