replacing TDA1514A to incrase power
Your question doesn't give us much to go on. However since the answer is there are no single chip amplifiers that give significantly more than 50W and none that are pin for pin compatible. You best bet unfortunately is probably to buy a bigger amplifier rather than try to modify the one you have.
To increase power you don't just need a higher power amplifier chip you will need a bigger power supply, higher voltage rated capacitors etc.
If you plan to design some thing from scratch then there are some amplifier modules that will provide significantly more power but I think the best chip amplifer is probably the LM3886 amplifiers at max power will provide 68W into 4R at 0.1% distortion on +/- 28V rails. But to be honest this increase in power is unlikely to be very noticeable in terms of listening levels.
Do you have some specific requirement for more output such as party or club playback system because a more sensitive speaker may be a better way to achieve it.
Andy
