Strange problem with LM3886 (chipamp.com) - diyAudio
Old 23rd February 2012, 07:30 PM   #1
Banned
Default Strange problem with LM3886 (chipamp.com)
Ive ordered a dual mono kit from chipamp.com. Everything is working except that when I meause the OUT (to speaker) and OUT GROUND (to speaker) It shows that OUT is - and OUT GROUND is +. Ive also meausured between OUT and CHASSIS GROUND and I get the same that OUT is - and CHASSIS GROUND is +.
The funny this is that it plays good whether I connect the speaker to OUT or OUT GROUND.
Here is a link to the assembly guide and scheme http://chipamp.com/docs/lm3886-manual.pdf
Hope anyone can assist me in this!
Thanks!
BR
GM
Old 23rd February 2012, 07:59 PM   #2
Banned
DC Offset is:
left mono I get -73,5mV
right mono I get -59,8mV
Old 24th February 2012, 01:46 AM   #3
6L6 is offline 6L6  United States
6L6's Avatar
Can you post some clear, well-lit pictures of your wiring? That would be an immense help.
Old 24th February 2012, 02:40 AM   #4
nigelwright7557's Avatar
Originally Posted by McDaisy View Post
DC Offset is:
Its because your dc offsets are negative.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 24th February 2012, 03:00 AM   #5
lanchile's Avatar
Thanks!
BR
GM
if output plus is the minus and output minus is the plus...just invert them!. I guess you made a mistake in the wiring.
Old 24th February 2012, 07:01 AM   #6
Banned
Of course I alreaddy checked that and they are not mixed!
To be more clear.
The OUT GROUND is 0V and the OUT is -59mV so the out is actually a phase its just that its below zero. Why is this?
I called a friend with the same kit yesterday and he had the same issue. He wasnr aware of it and has been listening for a year very satisfied...
Strange
Old 24th February 2012, 08:44 AM   #7
Banned
I talked with my friend who has the same kit. He has the exact same issue. He didnt know about it and he had been listening for almost a year very satisfied. Maybe this is correct..?
Anyways, since I have it in both channels and my friend has it in his both channels it cant be a soldering issue. Ive been soldeirng for 15 years so Im quite sure theres nothing wrong there. Im using a good weller station with appropriate temp and a suitable solder tip.
Old 24th February 2012, 08:45 AM   #8
Banned
I know... The question is. Why are my dc offset negative?
Both my PSU's are giving the correct voltage out... and everything is properly connected.
Old 24th February 2012, 06:08 PM   #9
Hi
Im trying the math....are you measuring the offsets with the i/ps disconnected and do they vary with i/p pot setting (assuming your using some).
Old 24th February 2012, 07:04 PM   #10
I don't see how the DC offset being positive or negative would be an issue. I usually like to see it at less than 50mV. I assume you have the optional Ci installed. Lowering the value of R2 may help.
- Richard
A strange problem with new chipamp build PJN Chip Amps 15 22nd May 2011 01:22 PM
Strange lm3886 distortion problem Oliphant Chip Amps 8 3rd November 2009 09:41 AM
Chipamp Lm3886 project, need help... Geoffroy Chip Amps 17 23rd October 2009 11:02 AM
ChipAMP LM3886 kit space-cake Swap Meet 1 22nd October 2008 09:43 PM
Copyright 1999-2017 diyAudio
