| Chip Amps Amplifiers based on integrated circuits |
#821 |
Leave me alone Andrew,
I'm one of those sensitive musician types and I might go over the edge.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#822 |
I've heard that some of the best musicians live on the edge. Why should you be any different from the geniuses?
#823 |
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 9th June 2012 at 03:51 PM. |
#824 | |
Hear the real thing! |
#825 | |
-------:------- As for speaker return current minimized loop area, see pic for the strategy (which is simple : keep send and return lines together). This is done by wiring at the bottom side of the PCB, no PCB change is necessary. Now it is drawn as a dead short, of course you must tee off the speaker send and return -- as a twisted pair -- at some point (but it does not matter where). There is something non-perfect there, still : the run allong asymetric lengths of V+ and V- lines, as well as the too big loop area of the GND plane vs supplies itself. Exact position would have to be found experimentally**) by injecting a magnetic field then moving the wire until lowest output is achieved. But to fix this on the PCB, it would be a major workaround, a complete rewrapping of signal and power paths... resulting in a short but wide PCB where power/relay stuff is left of the LM's and signal is right of them, strictly adhering to the star GND principle as well.... **) speaking of which, I'm OK again and will continue working on the PCB tomorrow.... |
#826 |
You really have big hopes that this improves the listening experience?
#827 |
Well, "big hopes" is a strong term but striving for layout/wiring which gives lowest possible interference (which can be quantified by measurement) has little chances to degrade perceived performance and is a prerequisite before any tweaking with boutique parts (and resistor orientation and similar things) makes sense. Some aspects of that are somewhat interconnected there, of course. And striving for the best circuit comes even before the layout/wiring, but in this thread we take the ciruit design as a given.
But that's only me, of course. Last edited by KSTR; 9th June 2012 at 04:44 PM. |
#828 |
KSTR, I have often wondered if balanced cables would make an audible difference with this or any MyRef/LM3886 design. Hopefully that subject will get some attention as things develop.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 9th June 2012 at 04:59 PM. |
#829 | |||||
Reality first!
I've started to test the C9/R10 mod and for sure it sound different.
With the position reversed (C9 to ground) there seem to be a more contrasted, direct sound with wider and deeper soundstage and tighter bass. The classic arrangement seems more 'soft', maybe confused. So far I would say Klaus'mod is effective in improving sound but I'll decide after listening again tomorrow... I don't want another ceramics debacle... ![]() Quote:
![]() Quote:
Limits given I don't feel it's a bad layout, is it? Quote:
I'll read with interest your tests results ![]() Quote:
Though it doesn't mean that the amp section can't be modified or improved. In fact:
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run Last edited by ClaveFremen; 9th June 2012 at 05:21 PM. |
#830 |
Bob,
A MyRef, as well as any other OpAmp design, could be modified to be a differential input (even and especially for a unbalanced source output). There are some issues though (like you need to know the source impedance which must be fixed, and for the MyRef you'd need a permanently attached cable). It would probably be easier and more generally useful to put a high impedance differential input/buffer ahead of a MyRef (which could be either the subtracting circuit itself or the input circuit does the subtraction). Many ways to skin a cat here.... |
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| fine tuning of tapered TL...can i do this??? | mondogenerator | Multi-Way | 6 | 8th December 2009 05:05 PM |
| F3 fine tuning | ZUM911 | Pass Labs | 5 | 31st January 2008 09:14 PM |
| Orion fine tuning | PT914 | Multi-Way | 6 | 14th February 2005 09:11 PM |
