Old 5th June 2012, 02:21 AM   #771
Bill_P is offline Bill_P  United States
Originally Posted by ClaveFremen View Post
This is a sort of a puzzle... but I'm pretty tired now 1.00AM here.
Maybe something like this?
I was thinking more like this:
Old 5th June 2012, 06:37 AM   #772
Reality first!
ClaveFremen's Avatar
Originally Posted by soongsc View Post
Dario, if you are going to swap C9 and R10, I would STRONGLY recommend you listen to it on the beta board or old MyRef first.
Thanks, more clear.
Now I understand why I couldn't imagine that... you were suggesting to swap C9 and R10 in circuit, not in layout...Klaus, do you meant the same thing?
I think this thing has to be tested and it's a bit more radical than what I would like to change...
Sorry, but I'll don't swap those components departing from any My_Ref ever done (official and unofficial) in this phase.
Today I'll be busy at work so I'll check the other suggestions this evening.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run
Old 5th June 2012, 07:44 AM   #773
KSTR is offline KSTR  Germany
KSTR's Avatar
Yes, swap C9 and R10 in the circuit, this was suboptimal from the very beginning (no disrespect for Mauro -- his original idea was and and remains to be one of the best ideas in chip amp history --, but any designer may make some decisions that are questionable). I would consider it a minor but very necessary change (I mean, you swap to components wired in series). It does not, and can not, change the sound (you guys certainly are overreacting here, IMHO) but it will increase noise immunity by a significant marging when done right... so it may be said "to change the sound" in a certain way.
Of course I leave it up to you if you want to change it or not. That applies in general to any suggestion that I will make (and there is no guarantee that I won't make even the slightest error as well, but I have a full blown audio lab at hand where I can quantify things pretty well, also of course decent listening and comparison facilities).
Old 5th June 2012, 08:31 AM   #774
soongsc is offline soongsc  Taiwan
soongsc's Avatar
In another chip amp, swapping those two components made significant difference. I do not know how significant it is in the MyRef design, so I would recommend trying it in reality to see if it makes a difference before changing it on board.
Hear the real thing!
Old 5th June 2012, 08:36 AM   #775
Reality first!
OK, so it's the same thing...
I'm having a look at National datasheets and whitepapers and in fact that capacitor goes directly to ground with the resistor preceding it.
Two different opinions...
I can't be sure that Mauro did a precise choice or not.
I'll give it a try on my TP modules.
Dario
Old 5th June 2012, 09:47 AM   #776
soongsc's Avatar
Remember to move the bypass cap too.
Old 5th June 2012, 12:13 PM   #777
billo44 is offline billo44  United Kingdom
billo44's Avatar
Originally Posted by SoIL4x4 View Post
Whoa! Same time, same topic, different continent. Billo are you reading my mind
Spooky eh!
Truth is I have enough trouble reading my own mind... must have been a co-incidence!
48 x 29 mm
It's easy since I've them at home...
Thanks Dario,
So these Russian caps are slightly smaller than the obbligatos we used in the my ref revc ultimate group buy last year.
For that build I put them in between the hot pins of the RCA input and the lightspeed input, seems to work OK to my ears. Here is a non technical build blog,
My Ref Revision C Ultimate GB (Green Mountain Edition) twiddlingmyknobs
Your up late again Dario working on the PCB design. Wish I understood and could contribute, but I know my limits...
Bill
Old 5th June 2012, 10:48 PM   #778
Reality first!
Default Status update
I've received confirmation from Suburra that beta boards with grounded heatsink and 97dB speakers the hum is no more audible.
So, to retain a proven design, I will try to mantain RC design as similar as possible to beta boards with some mods/enhancements.
This week till saturday will be dedicated to final tests by KSTR and Suburra, finalize the boards and eventually include some minor mod.
Sunday or Monday I'll proceed with the order.
Dario
Old 5th June 2012, 10:54 PM   #779
lehmanhill's Avatar
Dario,
I support staying with the proven concept. It's just my opinion, but I also wouldn't move R3 as Klaus suggested. It is a good suggestion, but most people will only attach the heatsink once, so ease of install is of limited value, at least to me.
Jac
Old 5th June 2012, 11:02 PM   #780
Reality first!
Hi Jac,
I do agree, at the moment the only mods to the initial RC design I'm quite sure of are the cutout to better isolate C14 ground return and the use of a through hole part for C10.
Dario
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 444 29th October 2012 11:38 PM
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 05:05 PM
F3 fine tuning ZUM911 Pass Labs 5 31st January 2008 09:14 PM
Orion fine tuning PT914 Multi-Way 6 14th February 2005 09:11 PM
Copyright ©1999-2013 diyAudio
