| Chip Amps Amplifiers based on integrated circuits |
#311 |
Reality first!
Not much, I've invested a lot of money on the amp and my speakers' crossover and first I must buy chassis for the amp.
Maybe next year project will be a MarkAudio fullrange speaker.
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#312 |
Wrong answer, Try Again.
![]() No, I feel the same pinch but am hoping there might be a suitable low cost driver or a "Midnight-Blue light" special that fits into a simple MFB box. Still looking. and FYI - I had to sell the refrigerator to be able to buy the True Copper Caps.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 28th April 2012 at 03:43 PM. |
#313 | |
Reality first!
![]() I've been lucky, I've had to sold only my microwave owen... ![]() At least at the end we'll all have a zen house full of music
#314 |
Fairly low and middle-of-the-range commercial 2-ways. One is a pair of JBL LX2001 bookshelves with a 6" woofer, 1" tweeter and 2nd-order XO; another is a Jamo Compact 60 with a ~4" woofer, 1" tweeter and 1st-order XO; and the third is a Kenwood LS-M33V bookshelf with ~4.5" woofer, 1" tweeter and 1st-order XO.
A speaker upgrade is on my wish-list, but I have lots more stuff on my plate now, so it will have to wait for a bit. |
#315 |
Hi Siva, Sorry for a bit of misunderstanding. I was following squalor's lead. Thought you had a FR.
Thanks for responding. squalor - you have to go stand in the corner for ten minutes ![]() P.S. Did you settle on a name for project X yet?
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 28th April 2012 at 04:46 PM. |
#316 |
Dario, I'm hearing lots of "fuzz" on things like Wynton Marsalias solo trumpet work in the upper regesters. Is that what you meant by HF distortion with the Elna Cerafines? Everything else sounds pretty smooth,warm and punchy. Cymbals are clean and bright and the drums and bass are distinct.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 28th April 2012 at 05:12 PM. |
#317 | |
Reality first!
It depends a lot on recordings, if HF is on the hot side in my systems high hats and sometimes voices and trumpets get a bit of hardness and harshness.
#318 |
Ditto - very source dependent. I'll have to make note of where I hear it so I can compare when the FGs arrive. It is a very good sound otherwise. Sounding quite clean and responsive now on a light classical piece - Overture to Hamlet.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 28th April 2012 at 05:49 PM. |
#319 |
Dario, I saw in post #11 that you are using r-core transformers. I've been reading on a few sites and the consensus appears to be R-cores for DACs and Preamps - toroids for power amps. Is there anything about the FE that would dictate a preference for either type?
And - other than the standard LM3886 specs, what would be your recommendation for the highest allowable trani rating for this design? Just thinking ahead on final build/chassis configuration.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#320 | |
MyRef_X2 sounds fine, unless some objections crop up. I'll wait for another couple of weeks at least, until the prototype PCBs show up. |
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| fine tuning of tapered TL...can i do this??? | mondogenerator | Multi-Way | 6 | 8th December 2009 05:05 PM |
| F3 fine tuning | ZUM911 | Pass Labs | 5 | 31st January 2008 09:14 PM |
| Orion fine tuning | PT914 | Multi-Way | 6 | 14th February 2005 09:11 PM |
