| Chip Amps Amplifiers based on integrated circuits |
#21 | ||
Reality first!
all through hole signal resistors are socketed (see attached magnification) so the difference is not soldering related. I've reversed it several times with always the same results. Takman REX, in my experience, are directional. The Same for PRPs. Quote:
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#22 | |
Hear the real thing! |
#23 | |
Reality first!
![]() I think that I've finally found where is the problem... LM317's power dissipation. When idle temperature on LM337 is 44 °C, on LM317 57°C (23°C room temperature). I've replaced both LM317, the new ones heatsinked, problem seems gone. What puzzles me is that when on breadboard this problem did not appear. Just for the sake of precision I've measured also both unregulated rails (+33,6Vdc and -34Vdc with 2x24Vac transformers) so there is not a voltage difference... So for all beta builders: buy TO-220 thin heatsinks for LM317s This Mouser code should be suitable: 532-576802B00
Dario ClaveFremen "Bailando Salsa en el Sietch" Last edited by ClaveFremen; 1st March 2012 at 06:17 PM. |
#24 | |
How many 68R and 270R should one buy to get a good match ? ... or can I pay PartsConnexion to match for me ? Interesting heat sink on your 3886. Are the Mundorf smoothing caps bigger (taller) than Panasonic TS-HA 50V at C101.201 ? Your M-Lytic are 10000uf 63V MLGO right. I think the chassis I am working on is too small. |
#25 | |
Reality first!
Maybe the fact that on breadboard there were more air around them... I don't know.
The 'heatsinks' are server heatsinks for harddisks... temporary, obviously... ![]() They're both 50mm tall.
#26 | |
#27 | |
Reality first!
I think the problem is not PCB related but to the fact that the PS components, probably, don't like the resistor swapping and get damaged. Just to be sure that it's not related to the amp section I've pulled out the entire PS and mounted the stock My_Ref PS, it sounds perfect. After that I've mounted again the shunt transistors and resistors, it seems to sound perfect (but better ) too.I've run out of LM317/LM337, in the next days I'll remount also them. Now that I have all components I've mounted also the voltage limiter, it seems it has no adverse effects.
#28 |
Reality first!
Today, I've mounted 14V BOM's zeners and so far it continues to sound good.
Just a note: while 1N53xx sounds fuller they, maybe have a touch of hardness but as hours are passing it seems to lower. According to tracking packages left Italy this friday so I think that between the end of the next week and the beginning of the next should arrive at beta testers' home.
#29 |
You can solder the pins on the PCB to avoid slaughtering of the card
#30 | |
Reality first!
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| fine tuning of tapered TL...can i do this??? | mondogenerator | Multi-Way | 6 | 8th December 2009 05:05 PM |
| F3 fine tuning | ZUM911 | Pass Labs | 5 | 31st January 2008 09:14 PM |
| Orion fine tuning | PT914 | Multi-Way | 6 | 14th February 2005 09:11 PM |
