My_Ref Fremen Edition - Beta build/Fine tuning
Old 10th August 2012, 05:10 PM   #1491
bcmbob is offline bcmbob  United States
WARNING - Dario pointed out the caps in post #1488 are not the correct spec. Those are Silmic II and not RJK. Not sure how much difference there is but, be aware they are not what is in the BOM. They are quite usable in those positions, just not the same. I ordered some so I'll try them out and report back.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 11th August 2012, 12:05 AM   #1492
soongsc is offline soongsc  Taiwan
soongsc's Avatar
One thing I can't understand is that why people choose polarized caps for a position that does not have DC offset? We don't to that in speaker XOs, why do we do it here?
Hear the real thing!
Old 11th August 2012, 01:32 AM   #1493
I believe that is one of the topics proposed for experimentation during the RC process. There will probably be several more.
Bob M.
Old 11th August 2012, 09:34 AM   #1494
R.I.P.
Soon,
the input DC blocking capacitor and the negative feedback, DC blocking capacitor locations, both have a DC offset. This is usually checked for during design and checked again at assembly time.
Have you never bothered to measure the offset on your polarised capacitors?
regards Andrew T.
Old 11th August 2012, 11:16 AM   #1495
soongsc's Avatar
Andrew, I think you are referring to something different from what I am talking about.
Old 11th August 2012, 12:08 PM   #1496
R.I.P.
Which polarised (electrolytic) capacitors are you referring to?
PSU, Decoupling, Coupling, DC blocking?
As far as I can see, all of these locations in the MyRef have a polarisng voltage applied to the capacitor.
regards Andrew T.
Old 11th August 2012, 05:31 PM   #1497
soongsc's Avatar
DC voltage needs to be such that polarized caps are never reverse polarized in operation. In MyRef, C9 really has no such voltage. Many chip amp applications implement the same way as well. Very curious about the considerations behind this.
Old 11th August 2012, 08:32 PM   #1498
R.I.P.
that is not a requirement.
Prevention of excessive reverse polarity is a requirement.
As far as I know electrolytics can tolerate 1000mVk to 1500mVpk of reverse polarity without suffering any degradation.
If you apply a 1Vac signal to an electrolytic coupling cap and it has 200mVdc offset then the worst case short term reverse polarity is ~1200mVpk.
But the capacitance of the capacitor does it's best to drag the undriven plate along with the voltage on the driven plate. That 1Vac signal can't actually apply anything like a 1200mVpk reverse polarity between the plates.
regards Andrew T.
Old 12th August 2012, 01:29 AM   #1499
soongsc's Avatar
So what about asymmetric leakage current?
Old 12th August 2012, 11:04 AM   #1500
R.I.P.
Would that appear as different from the AC signal that is coupled across the capacitor?
I don't know because I have never heard of that before.
regards Andrew T.
My_Ref Fremen Edition - Beta build/Fine tuningHide this!Advertise here!
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 05:05 PM
F3 fine tuning ZUM911 Pass Labs 5 31st January 2008 09:14 PM
Orion fine tuning PT914 Multi-Way 6 14th February 2005 09:11 PM
