My_Ref Fremen Edition - Beta build/Fine tuning - Page 138 - diyAudio
Old 25th July 2012, 02:19 AM   #1371
marcus1's Avatar
Default Mouser project sharing available?
Hi
I'm looking at ordering my parts thru Mouser. Is there a project sharing access number available (as required here: Mouser Electronics - Electronic Components Distributor that has all the parts required for the amp or is there another way of doing this?
I've looked at the google doc but can't figure out if the info to do the above is there.
Old 25th July 2012, 02:25 AM   #1372
No 4 is offline No 4  United States
Use the BOM import tool and copy and paste.
Old 25th July 2012, 08:12 AM   #1373
have anybody tried ELNA caps in FE power supply? Found these for very reasonable price and moreover, they are quite compact that's important to me (planning to install one board on another due to the lack of space).
Also what would be the best choise for C12 (220pf) if I cannot find Amstrans? fkp2 is available though, also found KP72 film/ foil , perhaps they would be more detailed/ natural?
for C13 I would use these Russian big ones , hope they are near Audyn's performance.
Old 25th July 2012, 08:18 AM   #1374
atupi is offline atupi  Romania
Those Elna looks strangely cheap. If you read on the product description the seller mention they are Nippon Chemicon so buy carefully.
Fkp2 has been used with good results in the previous versions. That russian capacitor for C13 has been recommended here being a good budget solution over more expensive options.
Old 25th July 2012, 08:53 AM   #1375
bcmbob is offline bcmbob  United States
Amtrans AMCH Series Film & Foil Capacitors
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 25th July 2012, 09:10 AM   #1376
atupi
indeed these Elnas look quite suspicious, better to confirm with seller that it's Elna.
bcmbob
thanks! Has already ordered different stuff from partsconnexion, hence see no point buying just Amstrans for this time.
Old 25th July 2012, 11:31 AM   #1377
seller confirmed that these are Elnas, Nichicons they sell as well.
Old 25th July 2012, 12:52 PM   #1378
Reality first!
ClaveFremen's Avatar
Sorry, no.
But I wouldn't use anything below 40V voltage rating.
FKP2 are a good choice, never tried those KP72, Amtrans are excellent.
They're very good caps with an incredible price/performance ratio.
Audyn True Copper are better, though.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 26th July 2012, 11:49 AM   #1379
thanks Dario!
yet another qestions regarding the components.
There is an alternative for R3 in BOM - another Caddock R that I need to order from somewhere.
Could FUKUSHIMA 0R47 5W be a replacement? Or perhaps 2 Dale 1R in parallel could be used as well?
In case it worths only to stay with these Caddocks, I guess I would get some simple ceramic wirewound 5W R then.
Old 26th July 2012, 01:00 PM   #1380
Reality first!
thanks Dario!
You're welcome.
You'll need a 5mm LS resistor, PCB can accomodate a vertical cement resistor (specified on the 'On a budget' BOM) but I don't know if those resistor you linked would fit.
BTW the Caddock in R3 represent a significative improvement over the cement wire resisistor...
If the problem is cost you can order MP915 instead of MP930, same quality and quite lower cost.
Dario
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 06:05 PM
F3 fine tuning ZUM911 Pass Labs 5 31st January 2008 10:14 PM
Orion fine tuning PT914 Multi-Way 6 14th February 2005 10:11 PM
Copyright 1999-2017 diyAudio
