My_Ref Fremen Edition - Beta build/Fine tuning
Old 11th July 2012, 10:21 AM   #1281
bcmbob is offline bcmbob  United States
Originally Posted by ClaveFremen View Post
In this moment the amp is configured with the usual C9 R10 order.
I hope to socket C9/R10 positions tomorrow.
If you're asking if C9 has a different impact if tied to ground instead of the usual position the answer is:
yes but it depends on caps.
With most caps the new position (tied to ground) reduces C9 impact on sound, the worse the cap, bigger the difference.
Dario, I also bought some of the BG F caps from the eBay source. Are you suggesting/supposing these would be a good candidate for the reverse positioning?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 11th July 2012, 10:33 AM   #1282
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by atupi View Post
After reading this i'be bought K71-4 and i also bought some K40Y-9 caps. Tested both and for my ears K40Y-9 sounds much more musical. I would say polystirenes are much more analithical and a bit boring compared to PIO.
K40Y-9 are very confortable to listen to but limited in HF extension, detail and (deliciously) colored.
K71-4 have full detail, refinement, deadly neutral, lacks just a tiny bit of bottom end.
If you listen to both, K40 seems 'more musical' but if you compare to DC coupling you'll find they're simply colored.
Dario between Amtrans and the other NOS ROE/Vishay that you sold as a 4.5EU package what would you choose ?
I could live with Amtrans with no regrets, they're the film/foil caps that most approach polystirene, just a tiny bit less neutral.
KP1834 in feedback is a small, but audible, improvement.
Where I would really miss KP1834 is in C7.
FKP2 100V fares very very well but KP1834s are way better, IMHO.
Originally Posted by lehmanhill View Post
I was interested in the Russian PIO caps, but hadn't gotten around to ordering any. I think I'll order them, just to try.
Be aware that they're enormous and they could be mounted only outboard.
I think they would be a good candidate for both C9 alternatives.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 11th July 2012, 11:10 AM   #1283
atupi is offline atupi  Romania
So far my last choice for C7 is KP1830 recycled from an old german equipment. I will try in the future also your recommendation KP1834.
Old 11th July 2012, 02:37 PM   #1284
Just ran across a sildering video with some good images. Not specific to what's on the FE, but fun to watch for folks starting out.
Professional Hand Soldering (Basic to Advance) - Surface Mount, Through-Hole, Wires & Terminals - YouTube
Bob M.
Old 12th July 2012, 11:34 AM   #1285
Warning!! Still way off topic.
On the other side there is solder removal.
Pace Inc. (5) Vacuum Desoldering components SX-Series - YouTube
A Simple but expensive Pro tool. $650+
Hakko FM204-01 Desoldering Station and FM204-CP Conversion Port Desoldering & Soldering Station - YouTube
Cheapest I could find on eBayEbay.
Aoyue 474A+ Desoldering Station | eBay
O.K. So with all this research I've done - as a reward - you guys can start taking up a collection and buy me one of these for Christmas.
Hakko FM-206 Desoldering Rework Station from All-Spec Industries - YouTube .
Here's one with "Sound Effects"
Bob M.
Old 15th July 2012, 12:41 AM   #1286
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
You are confusing me now (not that hard to do). I didn't populate C101/C201. Is "MLGO" the significant factor for use at C9, and are you saying - same cap but different value?
As I recall, there were some caps that were thought to be optional to mount or not. Do I recall correctly that they were the C102/C202, the smoothing caps for the regulated power supply? It appears that they would reduce ripple from the mains going to the 318.
Or were they C1, C2 which add power supply smoothing to the LM3886?
Whichever were the choice, was the consensus not to mount them?
Jac
Old 15th July 2012, 12:53 AM   #1287
All I can report is I tried two different caps in C102/C202 and nothing sounded better than no cap there. I might test something again on the RC build.
Bob M.
Old 15th July 2012, 01:55 PM   #1288
Reality first!
First of all:
I this last days I've been out of town for work so I don't even know if blue boards arrived.
I would probably been able to give some news next tuesday.
To my (and Bob and Suburra) ears the amp sounds better with C102/C202 unpopulated.
It's true ripple is further reduced using them but probably the caps signature impair (soundwise) the advantage.
Dario
Old 15th July 2012, 06:07 PM   #1289
Black Gate F caps are Ginormous. FE boards have proper spacing if standard placement is used.
Earned - "Best Shipping Award" - they came inside non-static bags, inside bubble wrap, inside this container, inside bubble wrap, covered with paper, inside plastic bag, in a cardboard box stuffed with shredded newspaper - SERIOUSLY. Half way through I thought I was going to find a fortune cookie saying "April Fools!"
Bob M.
Old 15th July 2012, 06:58 PM   #1290
Reality first!
half way through I thought I was going to find a fortune cookie saying "April Fools!"
I 'm curious to read your impressions
Dario
My_Ref Fremen Edition - Beta build/Fine tuningHide this!Advertise here!
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
fine tuning of tapered TL...can i do this??? mondogenerator Multi-Way 6 8th December 2009 05:05 PM
F3 fine tuning ZUM911 Pass Labs 5 31st January 2008 09:14 PM
Orion fine tuning PT914 Multi-Way 6 14th February 2005 09:11 PM
