| Chip Amps Amplifiers based on integrated circuits |
#111 |
O.K. I have actually wondered if/when you got some time to sleep.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#112 |
Reality first!
I've checked Mouser's shared BOM and it includes caps (Nichicon FW) for C102/C202 but in this moment they're not available, maybe this is the reason you didn't received them, Bob.
BTW It could be better this way, they're not so good for those positions, final BOM will have different caps (probably FG: 647-UFG1H101MPM) Cerafines are very good caps for those position.
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#113 |
Thanks, I found some 100uf / 50V from the MyRef 1.3/1.2 builds. I'll add something better to my next order.
Here are the pics of all installed other than Heat Sinks, Relay. LM3886 (I think) Please review. FE-1
#114 |
FE-2
#115 |
Reality first!
At a first glance it seems fine...
I can't read LM337, BC639 and BC640 markings, check them against silk screen (just to be sure ... ).
#116 |
Same on both boards.
#117 |
Reality first!
Seems fine
#118 |
Just found a mistake
![]() I mounted and trimmed R3 before attaching the heat sink so now the leads are too short. I remember one must do this with the LM3886 chips but I totally forgot it on R3. Luckily I have some double sided CPU heat transfer tape I can use till I get some new parts
#119 |
Sockets filled, Relay in and LM3886 installed.
If you see something - say something,
#120 | |
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| fine tuning of tapered TL...can i do this??? | mondogenerator | Multi-Way | 6 | 8th December 2009 05:05 PM |
| F3 fine tuning | ZUM911 | Pass Labs | 5 | 31st January 2008 09:14 PM |
| Orion fine tuning | PT914 | Multi-Way | 6 | 14th February 2005 09:11 PM |
